what do you 5.9 owners idle/drive at temp wise ? - JeepForum.com
post #1 of 26 Old 11-21-2010, 09:20 PM Thread Starter
Candymancan
Was just wondering people with 5.9's what do you guys idle and drive at temp wise ? Seems mine hangs around 180-190f and never gets to 210f. Oh and what is your oil pressure usually at ?
Just want to compare
Candymancan is offline
post #2 of 26 Old 11-21-2010, 09:51 PM
NW-XJ
NW-XJ's Avatar
idle: 720ish
Temp: 180* T-stat.. rarely gets above 190*
Oil pres:Mine is Canadian, so it's shown in "Bar" but it normally sits about half, in mornings or under WOT it sits about 7/8 up the gauge..
5.9 ZJ
add ons: Go fast stuff, Stop fast stuff, offroad stuff, and bright lights.
NW-XJ is offline
post #3 of 26 Old 11-21-2010, 10:03 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Bar is pressure not temperature...
If it only gets to 190 your have a 180* tstat. either get it tuned to work better with the lower tstat(sct tune) or change it to stock next time you feel the need to get into the coolant system.
ratmonkey is offline
post #4 of 26 Old 11-21-2010, 11:13 PM
NW-XJ
NW-XJ's Avatar
Right. Bar is Pressure.. thats why the oil Pressure sensor is shown in Bar
180* T-stat is for the Mopar performance PCM.. the gauge likes to read about 85* Celsius.. to be more exact, the gauge reads about 185*F
jeez.. nit picky bastad
5.9 ZJ
NW-XJ is offline
post #5 of 26 Old 11-21-2010, 11:56 PM Thread Starter
Candymancan
How woud you know if you have the performance PCM installed ? Is it just a simple flash or would the entire computer box be different ?
post #6 of 26 Old 11-21-2010, 11:58 PM
NW-XJ
NW-XJ's Avatar
different Part number on the PCM
5.9 ZJ
NW-XJ is offline
post #7 of 26 Old 11-22-2010, 12:00 AM Thread Starter
Candymancan
Any idea what the number is so i can go check mine.
post #8 of 26 Old 11-22-2010, 12:15 AM
newfieZJ
newfieZJ's Avatar
#56041 519AA 1 EM0 DG0 Federal
#56041 538AA 1 EM0 DG0 California
Make sure it's not death flashed , here's what that sicker would look like
newfieZJ is offline
post #9 of 26 Old 11-22-2010, 12:25 AM Thread Starter
Candymancan
Mine says
56041 519AE
The rest was just a serial number.
post #10 of 26 Old 11-22-2010, 12:47 AM
NW-XJ
NW-XJ's Avatar
P04876 898 -Federal Mopar PCM for 5.9
5.9 ZJ
NW-XJ is offline
post #11 of 26 Old 11-22-2010, 12:59 AM
newfieZJ
newfieZJ's Avatar
Here's every PCM listed for 98 :
#56041 515AA 1 J EL0 DG0 Federal
#56041 516AA 1 T EL0 DG0 Federal
#56041 517AA 1 J EL0 DG0 California
#56041 518AA 1 T EL0 DG0 California
#56044 513AA 1 ER0 DG0 Federal
#56044 514AA 1 ER0 DG0 California
Can't find your # anywhere
newfieZJ is offline
post #12 of 26 Old 11-22-2010, 01:00 AM Thread Starter
Candymancan
I tried to look it up on google also but i couldnt find it.. I did find a couple but they were on some Russian website at least i think it was russian.
Do you want me to take a picture of it ?
post #13 of 26 Old 11-22-2010, 01:07 AM Thread Starter
Candymancan
i found one website with PCM codes like mine, however there isnt any info other then the codes
http://www.elecauto.com/chrysdc.htm
post #14 of 26 Old 11-22-2010, 01:17 AM
NW-XJ
NW-XJ's Avatar
Here's where i got my info, And it also matches the New-to-me PCM i installed 2 weeks ago
Does the 5.9 have performance ECU? - North American Grand Cherokee Association
5.9 ZJ
NW-XJ is offline
post #15 of 26 Old 11-22-2010, 01:27 AM
newfieZJ
newfieZJ's Avatar
I knew that # looked familiar , the performance PCM isn't in the parts lists
newfieZJ is offline
bad idle and bad coolant temp sensor Sontizzle ZJ Grand Cherokee Forum 6 07-29-2008 11:29 PM
Stalling at idle in Drive Clifford97GC ZJ Grand Cherokee Forum 2 01-24-2007 10:38 PM
Selec-Trac - Quadra Drive I & II Comparison...WJ Owners Needed Kurdoncob ZJ Grand Cherokee Forum 70 10-07-2006 03:26 PM
ZJ Owners - Whats your idle rpm Ruffy ZJ Grand Cherokee Forum 11 02-22-2005 04:47 AM
High Temp During Idle DAVEH ZJ Grand Cherokee Forum 0 07-28-2004 02:39 PM
