Weak headlights on 97 ZJ. - JeepForum.com
 50Likes
post #1 of 46 Old 08-02-2021, 10:49 PM Thread Starter
zjlockers
Anyone experience this?
I am using this standard halogen bulb below from OReillys.
I tried re-grounding the black-harness wire to the vehicle-frame as in below youtube video -- made no difference.
Do I need to try a better bulb or what do I need to do?
Please keep in mind I acquired the vehicle less than a week ago.
https://www.oreillyauto.com/detail/c...ght+bulb&pos=0
zjlockers is offline
post #2 of 46 Old 08-02-2021, 11:35 PM
riiz
riiz's Avatar
Replace the harness altogether and run the lights directly from the battery. I've installed 2 of these kits for Ksuspension and only takes about 30 minutes to install.
https://www.ksuspensionfab.com/store...Harness.html#/
riiz is offline
post #3 of 46 Old 08-03-2021, 02:03 AM
PolkaPower
PolkaPower's Avatar
Or build yourself a nice pair of HID lights. Maybe around 230 bucks. img_20180221_171707.jpg
Sent from my iPhone using Tapatalk
Kolak and zjlockers like this.
PolkaPower is offline
post #4 of 46 Old 08-03-2021, 04:05 AM
yjsaabman
1930 CJ2
Building a set of HID lights is on my list. I added some old Bosch fog lights I had around and they have helped, as did some new housings with fresh lenses. Still just an old design that can't compete with modern lighting.
Sent from my SM-G970U using Tapatalk
zjlockers likes this.
yjsaabman is offline
post #5 of 46 Old 08-03-2021, 04:06 AM
PolkaPower
PolkaPower's Avatar
The wiring harness upgrade makes a noticeable difference.
Wyo and zjlockers like this.
post #6 of 46 Old 08-03-2021, 06:24 AM Thread Starter
zjlockers
My original harness (shown below, 97 ZJ) does not look anything like his original harness. Do they include adapters for
my type of original-harness?
Also, I am gonna need a lot more than 50% increase in brightness. I can barely see 20feet in front of myself -- almost
impossible traveling at night on the gravel roads out in the middle of the crop-fields.
https://imgdump5.novarata.net/kfldna.jpg
3:00 and 3:51
post #7 of 46 Old 08-03-2021, 06:37 AM Thread Starter
zjlockers
Btw, what's the difference between the $23 headlights and the $220 headlights?
https://www.oreillyauto.com/shop/b/l...ens%2Fassembly
post #8 of 46 Old 08-03-2021, 08:13 AM Thread Starter
zjlockers
Since I could not really find any effect of using a fresh ground, I am gonna try these LED headlights, together
with these fresh-plastic assemblies.
Hopefully I will eventually get something usable.
"Nilight 9004/HB1 LED Headlight Bulbs, 70w 14000lm 9004 Hi/Lo Beam LED Headlight Bulb 6500k 9004 LED Bulb Cool White IP67" at amazon.com
https://www.oreillyauto.com/detail/c...assembly&pos=2
post #9 of 46 Old 08-03-2021, 08:24 AM
Mark-318-IT
following, i have that harness and the euro spec headlighs, but i'm far from seeing well when i drive at night.
360swapped:np242swap,shift kit,BOLT ONs,ome HD coils,aussie locker,dana30hp trussed
Mark-318-IT is offline
post #10 of 46 Old 08-03-2021, 08:58 AM
Rockpile
Rockpile's Avatar
1994 ZJ
I installed the new harness from KSuspension fab with new housings and Sylvania bulbs last year. Big improvement over the original stock stuff.
Rockpile is offline
post #11 of 46 Old 08-03-2021, 09:01 AM
jay-h
Almost always it's due to voltage drop. I would start looking there. If your wiring is weak, getting more powerful lights may make things worse.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #12 of 46 Old 08-03-2021, 09:08 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yup, the major flaw in the ZJ headlights a is the voltage drop from all the wiring. A relay harness is the best bang for the buck in upgrading them.
kg6mov is offline
post #13 of 46 Old 08-03-2021, 09:16 AM
Mr. Puddles
If you are going to order LED bulbs Id HIGHLY recommend you go to superbrightLEDs.com Ive done whole interior and exterior bulb sets from them with zero issues.
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #14 of 46 Old 08-03-2021, 11:19 AM Thread Starter
zjlockers
You convinced me. I just added the 9004/9007 harness from ksuspensionfab.com, $25 plus shipping is $33. So, that and already $50 for the two LED bulbs and $88 for the two fresh-plastic housing/assemblies, $171 total so far. If that doesn't fix me, I don't know what will
post #15 of 46 Old 08-03-2021, 02:32 PM
yjsaabman
1930 CJ2
I read a really good article on headlight bulbs a year or so ago and I wish I had saved it to share. It was about changing the bulb type in a housing and the effects it can have. Basically, for the housing and lense to distribute the light properly you should stick with the bulb style it was designed for. An LED bulb doesn't put out light the same way a halogen bulb does, so a halogen housing won't properly distribute the light. You may be seeing better, but is the beam pattern right? Think about those cars with the obnoxiously bright headlights that glare and blind you. Do you want to be that person?
Multisyn and zjlockers like this.
