Water oil separator - JeepForum.com
 1Likes
post #1 of 16 Old 12-27-2019, 07:15 AM Thread Starter
Wolfeman1992
Wolfeman1992's Avatar
1994 ZJ
Water oil separator
I keep getting water up the breather tube for my valve cover and into my oil, y'all think a in line oil water separator for a air compressor would help?
94 ZJ 4.5" on 31s
Wolfeman1992 is offline
post #2 of 16 Old 12-27-2019, 08:05 AM
jay-h
Probably not. Water separators are basically designed for pumped flow like removing water from a diesel fuel line.
I would be more concerned about where this water is coming from. If you live in a very damp area you might see a little water in the tube from condensation.. however you state you see in in your oil?
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #3 of 16 Old 12-27-2019, 08:14 AM Thread Starter
Wolfeman1992
1994 ZJ
I probably should have include this part, I'its a Mud toy my engine bay is covered in red clay
94 ZJ 4.5" on 31s
post #4 of 16 Old 12-27-2019, 08:20 AM
zjosh93
I doubt a water separator from an air compressor would work. Different pressures and air flows.
The stock breather takes air from the intake tube after the air filter. Is your air filter getting wet or do you have the breather tube rerouted. You could always move it somewhere dry. It's just a source of fresh air for the CCV system.
zjosh93 is online now
post #5 of 16 Old 12-27-2019, 08:26 AM Thread Starter
Wolfeman1992
1994 ZJ
I'll probably just end up doing a junkyard cowl intake I was just hopping for a quick fix to get me through the weekend the local pit is flooded
94 ZJ 4.5" on 31s
post #6 of 16 Old 12-27-2019, 08:48 AM
zjosh93
Moving it is easy. Just buy a few feet of 1/2" PCV hose from your local parts store, a 1/2" barbed union, and a cheap universal breather filter. Then you can put it wherever you want. IMS there is enough of a gap near the hinges to let you stick the breather in the cowl but I'm not 100% on that.
You can use 1/2" heater hose temporarily but eventually the hot oil vapor from the engine will make it soft and it'll fail.
post #7 of 16 Old 12-27-2019, 09:21 AM Thread Starter
Wolfeman1992
1994 ZJ
Hey I have all of that laying around that should do it for this weekend
94 ZJ 4.5" on 31s
post #8 of 16 Old 12-27-2019, 09:31 AM
1996maroonzjf
1996maroonzjf's Avatar
94 ZJ 4.5" on 31s
Look into the Ford Windstar cowl intake swap. It’s a paper cone filter that moves a lot of air. Lots of TJ guys go that route.
I’m sure you could also reroute the pcv at the same time.
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is offline
post #9 of 16 Old 12-27-2019, 09:43 AM
PolkaPower
PolkaPower's Avatar
https://trailheadoffroad.com/shop/page/2/
Sent from my BND-L24 using Tapatalk
PolkaPower is offline
post #10 of 16 Old 12-27-2019, 09:56 AM
jay-h
Since the stock (I assume yours) breather takes it from the air cleaner, perhaps you should consider a snorkel or other modification. You want to be careful what goes through the throttle as well
Wolfeman1992 likes this.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
jay-h is offline
post #11 of 16 Old 12-27-2019, 09:57 AM Thread Starter
Wolfeman1992
1994 ZJ
I'll check into that one, this is the one I was gonna do
http://spacecoastjeepclub.com/Forums...php?f=29&t=115
94 ZJ 4.5" on 31s
post #12 of 16 Old 12-27-2019, 10:00 AM Thread Starter
Wolfeman1992
1994 ZJ
I've been trying to avoid going to a snorkel, though with all the rain we've been getting I may not have a choice theres parts of the pit that are close to 5ft deep though by that deep everything else would be full of water as well ask me how I know
94 ZJ 4.5" on 31s
post #13 of 16 Old 12-27-2019, 05:17 PM
Mr. Puddles
94 ZJ 4.5" on 31s
At that depth I think you need to be more concerned about the electrical system.
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is online now
post #14 of 16 Old 12-27-2019, 05:58 PM
Timo_90xj
Timo_90xj's Avatar
Grease every single electrical connector you have in your Jeep, protect electrical components the best you can, block the transmission breather located in the fluid pump and relocate it to top of transmission housing with an a tube all the way to cabin roof.
Hope for the best, and be prepared for plenty of issues in the near future. These things aren't built for deep mud..
***Under construction***
Timo_90xj is offline
post #15 of 16 Old 12-27-2019, 07:33 PM Thread Starter
Wolfeman1992
1994 ZJ
Yea I plan on staying out of anything that deep, throwing a rod and draining strawberry milk from my trans taught me that lesson
94 ZJ 4.5" on 31s
