VIC burned out resistor? - Page 2 - JeepForum.com
 1Likes
post #16 of 22 Old 01-27-2016, 12:31 PM Thread Starter
DrReaper
Originally Posted by kg6mov View Post
*Digs in parts bin*
In my spare, fully functional, 98 VIC there is no component in that position, just empty pads.
Ok thanks I will re solder the rest and replace.
DrReaper is offline
post #17 of 22 Old 01-30-2016, 06:35 PM
jswerve
My contacts looked good, even under a magnifying glass. I soldered them anyway. My Jeep has been coolant sensor low free for over 6 months after beeping for almost 10 years.
1998 5.9 |3.5" IRO lift w/adj CA and track bars | Bilstein 5100 | TJ Rubi wheels 245/75/16
jswerve is offline
post #18 of 22 Old 02-12-2016, 08:06 PM Thread Starter
DrReaper
We soldered the board and replaced it. It looks good now. I think the best thing about my jeep is the support I get here! Really enjoying fixing things as they come up.
DrReaper is offline
post #19 of 22 Old 12-22-2018, 08:16 AM
hsk3437
vic transistor problem
I need to Vic transistor serial numer datasheet.
hsk3437 is offline
post #20 of 22 Old 12-23-2018, 01:23 PM
muddflow
Those VIC boards are covered with a conformal coating. The coating should be removed to help see what your looking at and also to perform any re-soldering of parts and traces.
https://en.wikipedia.org/wiki/Conformal_coating
Some people use a plastic tool to scrape it off or you can use a conformal coating remover such as
https://www.zoro.com/techspray-confo...-n/i/G4278102/
muddflow is offline
post #21 of 22 Old 03-14-2020, 11:45 PM
sushilx
ZJ VIC Failure
i recently had similar issue of my 97 ZJ V8, there was a burning smell and the fuse blown out. Both RADIO and AC control stopped working alone with VIC. I found the VIC power transistor failed and
due the PCB track short/arcing at the high voltage area (@ 53V for VFD). After tracing the base/gate circuit, I tried to substitute MOSFET IRFZ46N (since original P/N is not visible and no correct information available on forums) . It works fine so far. Any 60-80v MOSFET with Id 26A or higher may work. There may chances for capacitor failure, mine all of them are fine.
Benthal8 likes this.
sushilx is offline
post #22 of 22 Old 03-16-2020, 11:22 PM
fawndog
fawndog's Avatar
If it's any help, I have 2 VICs for cheap, I gave up on trying to make one work. The other is from a 95, condition unknown.
$20 shipped.
fawndog is offline
vic , zj
