Is this vehicle below going to have to swap axles to put ARB lockers in the rear and - JeepForum.com
 11Likes
post #1 of 24 Old 07-24-2021, 09:10 PM Thread Starter
zjlockers
Is this vehicle below going to have to swap axles to put ARB lockers in the rear and front?
1997 Jeep Grand Cherokee Limited Sport Utility 4D, V8, 5.2liter
arbusa.com/guides/vehicle-application-guides
zjlockers is offline
post #2 of 24 Old 07-24-2021, 09:42 PM
PolkaPower
PolkaPower's Avatar
No. ARB makes an air locker for the 44a and D30.
44a=44hd
I probably wouldn't put an arb in the D30. It's already a weak axle. Maybe a HP30 with truss and C gussets. Still polishing a turd though. Depending on what size tires you are going run will determ8ne reliability.
I broke my open d30 with 33s.
https://eastcoastgearsupply.com/i-23...ker-rd226.html
Sent from my iPhone using Tapatalk
zjlockers likes this.
PolkaPower is offline
post #3 of 24 Old 07-24-2021, 10:05 PM Thread Starter
zjlockers
44a=44hd
I was looking at the ARB footnote where it says:
"quadra-drive traction control vehicles require non-quadradrive axle shaft replacements for air locker installation."
post #4 of 24 Old 07-24-2021, 10:08 PM Thread Starter
zjlockers
So, I am hoping it's not quadra-drive coz if it is I can't even put a locker on the rear.
post #5 of 24 Old 07-24-2021, 10:17 PM
PolkaPower
PolkaPower's Avatar
v8s come with 249 Quadra drive from the factory. You can use selectable lockers with 96-98 since the power split is 90 rear 10 front so it's rwd most of the time unless the rear tires lose traction. Selectable lockers have little impact on it since they are only used intermittently off road.
You can also swap a 242 from a 96-98 4.0 and it's a direct bolt in. You may have to shorten the rear shaft.
I had an Aussie locker in the rear of mine with the 249 for a while with no ill effects. The front would have been horrible though with a lunchbox locker. Selectable no problem.
post #6 of 24 Old 07-24-2021, 10:41 PM Thread Starter
zjlockers
I am only interested in the selectable lockers such as ARB air-lockers (arbusa.com) or ox-lockers (ox-usa.com).
Was hoping to put a selectable-locker on the front and on the rear.
post #7 of 24 Old 07-24-2021, 10:42 PM Thread Starter
zjlockers
(I have no interest in automatic lockers.)
post #8 of 24 Old 07-24-2021, 10:42 PM
PolkaPower
PolkaPower's Avatar
Ok so buy them and put them in then lol. I'm explaining why selectable is ok when auto lockers the front isn't to give you a better understanding since you don't quite fully grasp the functionality of the 249.
post #9 of 24 Old 07-24-2021, 10:43 PM Thread Starter
zjlockers
If I do that, will I even be center-locked? I dunno about this crazy quada-drive stuff. I just want to run with selectable lockers where all four wheels turn at the exact same rate, when I ask them to.
post #10 of 24 Old 07-24-2021, 10:45 PM
PolkaPower
PolkaPower's Avatar
In lo range the viscous coupler on 96-98 is bypassed and front and rear shaft are locked together like any other tcase.
If you activate the lockers they will function like you want no matter if you are in 4hi or 4lo.
post #11 of 24 Old 07-24-2021, 10:46 PM Thread Starter
zjlockers
Yeah, I know ZIP about quadra-drive.
post #12 of 24 Old 07-24-2021, 10:48 PM
PolkaPower
PolkaPower's Avatar
You might put a little extra wear and tear on the viscous coupler in 4hi with the lockers activated but 4lo is totally fine.
The viscous coupler wears out eventually over time anyway. Usually about 120k miles. Most people swap tcase because a new viscous coupler is about 400 bucks.
post #13 of 24 Old 07-24-2021, 10:52 PM Thread Starter
zjlockers
Still hoping I won't have to swap the axles though, again referring to the footnote at ARBUSA.com:
If I don't have to swap axles, I will be happy with my vehicle purchase.
post #14 of 24 Old 07-24-2021, 11:00 PM
kg6mov
Hears the voices
kg6mov's Avatar
No!
The ZJ never had quadra drive. That's the wj system, with weird lsd in both axles.
The ZJ has quadra trac, which is just a t-case, the 249. The axles are normal d30/d44a and take an arb just fine.
Kolak and zjlockers like this.
kg6mov is offline
post #15 of 24 Old 07-24-2021, 11:04 PM Thread Starter
zjlockers
Originally Posted by kg6mov View Post
No!
Ohhhhhhhhhhhhhhh, perfect, that's exactly what I wanted to confirm before making the vehicle purchase. ty ty ty ty.
