Transmission swap or sell? - Page 2 - JeepForum.com
 1Likes
post #16 of 18 Old 05-15-2019, 04:19 PM Thread Starter
TheRaccoon
1994 ZJ
update on the transmission
It was indeed the governer pressure solenoid. it still hunts gears occasionally and i suspect it needs a band adjustment but i have that slated to be done.
TheRaccoon is offline
post #17 of 18 Old 05-15-2019, 11:40 PM
PolkaPower
PolkaPower's Avatar
A ZJ with a bad transmission is worth scrap.
Sent from my BND-L24 using Tapatalk
PolkaPower is offline
post #18 of 18 Old 05-16-2019, 04:40 AM
V8GCZJ
You need to replace both the pressure sensor and the solenoid. They work in tandem to shift the transmission. One tells the pcm what the pressure is then the pcm tells the solenoid to engage that will shift the trans.
V8GCZJ is offline
