Transmission Fluid Pan - JeepForum.com
post #1 of 5 Old 07-12-2019, 08:40 PM Thread Starter
chillywilson
chillywilson's Avatar
Hi there, tranny pan has been leaking for some time. Found that the one of the corners of pan was warped and wasnt sealing properly. I found the gasket kit but cant seem to find the right pan to go along with it. Looking for the pan that goes with this gasket:
chillywilson is offline
post #2 of 5 Old 07-12-2019, 10:01 PM
kg6mov
Hears the voices
kg6mov's Avatar
It would be easier to give us year and engine.
The looks like a 46rh/re pan, so first gen V8 or niner?
I'm a fan of the summit cast aluminum pans, also highly recommend getting the mopar reusable gasket. Summit pan: https://www.summitracing.com/parts/sme-1009r
Rockauto and amazon have A518/46rh stamped pans, parts store should too.
kg6mov is offline
post #3 of 5 Old 07-12-2019, 10:06 PM Thread Starter
chillywilson
I'm a fan of the summit cast aluminum pans, also highly recommend getting the mopar reusable gasket. Summit pan: http://www.summitracing.com/parts/sme-1009r
Yes, it is the1994 5.2L V8. And thanks, kept trying to find them but for some reason none were coming up and kept finding the one I didnt need.
post #4 of 5 Old 07-13-2019, 04:52 AM
Timo_90xj
Timo_90xj's Avatar
If you order the aluminum pan from summitracing, add in a Lubelocker transmission pan gasket (and diff. cover gaskets too for that matter). I just installed a Lubelocker in my OEM pan that has had leaks for the past 7 years - not a single drop after the lubelocker.
I'm very confident in their quality, I still have the original Lubelocker in my front axle that I bought in 2007 - it's on my fourth D30 and still no leaks even though my DIY heavy duty diff cover and the housing itself has suffered serious rock rash on the bottom lip.
***Under construction***
Timo_90xj is offline
post #5 of 5 Old 07-13-2019, 06:49 AM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
Here is the Derale cooling pan used on my 46RH, as-shown in the wingless 46RH rebuild topic.
This is a deep pan w/ cooling tubes to drop the transmission fluid temperature.
wingless is offline
