TransGo Shift Kit--545RFE - JeepForum.com
post #1 of 12 Old 08-30-2006, 04:56 PM Thread Starter
Smith Erick
Smith Erick's Avatar
Who here has done the install thereself? I read the insructions and it dosn't seem too hard. I might as well change the fluid and sump filter while im in there. Im not that mechnically inclined but I put my own lift on. Should this be something I should tackle?
If anyone has done it, please post how hard the install was and and complication's that might arise..
Thanks,
Erick
"Smith Erick"
2004 Jeep Grand Cherokee Special Edition--4.7L V8
15% Tint, Front Tow Hooks, Skid Plates
Yakima Towers and Bars
Uniden Pro510 CB with taillight mounted 3ft. Fire Stik Antenna
Full Aftermarket Infinity Speakers w/ JL 10W7
Kevin's Round Bar Rock Sliderz powdercoated Black
Kevins 2.5 BB w/ Procomp MX-6 shocks
JKS Quicker Disconnects
OME SS
Addco Rear Sway Bar w/ Energy Bushings
TransGo Shift Kit
Kolak Exhaust
15in Crager Streetlocks
31"x10.5" Firestone Destination M/T's
Smith Erick is offline
post #2 of 12 Old 08-30-2006, 05:11 PM
Swamp Boy
Swamp Boy's Avatar
I did it in my 46RH.. Its not as hard as you would think...I just used the instruction sheet that came with it.. Took less than an hour..
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 12 Old 08-30-2006, 05:17 PM
Diehard
Diehard's Avatar
Almost mirror image
First, your GC looks almost like mine, except for the tires, Revos on mine, and I also have some other upgrades, (see my gallery). But what will the shift kit do for you? Won't help when you off-road will it? Improve gas mileage? Just wondering. Thanks.
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker.
Diehard is offline
post #4 of 12 Old 08-31-2006, 10:33 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
If you can do your own lift then you should be able to do a **** kit with instructions.
2013 FR-S
BlaineWasHere is offline
post #5 of 12 Old 08-31-2006, 10:37 AM
nierace
nierace's Avatar
2003 WJ
I think you missed a pretty important letter there Blaine
nierace is offline
post #6 of 12 Old 08-31-2006, 10:39 AM
BlaineWasHere
BecauseRacecar
pretty sure I typed shift... hahaha
2013 FR-S
post #7 of 12 Old 08-31-2006, 12:27 PM
capeennui
Guest
BTDT.
Its really pretty easy, just make sure you have the time and a clean working environment. And I'm an advocate of Redline C+ fluid for re-fill....but thats just me.
Nice results.
capeennui is offline
post #8 of 12 Old 08-31-2006, 12:30 PM
BlaineWasHere
BecauseRacecar
Originally Posted by SMTCapeCod
BTDT.
Nice results.
I'm sure what you are talking about but his (and yours) tranny needs ATF+4 fluid.
2013 FR-S
post #9 of 12 Old 08-31-2006, 01:11 PM
Swamp Boy
Swamp Boy's Avatar
Amsoil is the only way to go...
Buy it from ....4x4oil.com
post #10 of 12 Old 08-31-2006, 01:13 PM
BlaineWasHere
BecauseRacecar
Shameless plug?
2013 FR-S
post #11 of 12 Old 08-31-2006, 01:15 PM
capeennui
Guest
I know
Well aware, it meets ATF +4 specs:
http://www.redlineoil.com/products_g...59&subcatID=19
post #12 of 12 Old 08-31-2006, 01:18 PM
BlaineWasHere
BecauseRacecar
OK have at it then...
2013 FR-S
Manual Shift Auto Tranny (manumatic) 45RFE, 545RFE ? CTORT ZJ Grand Cherokee Forum 7 08-02-2014 04:36 PM
Possible WJ 545RFE Issue? WiCkeDuDe ZJ Grand Cherokee Forum 3 10-26-2009 08:08 PM
545RFE-Any changes? Dieseljoe WK Grand Cherokee & XK Commander Forum 4 04-11-2008 08:45 AM
Transgo Shift Kit/Torque Managment Smith Erick ZJ Grand Cherokee Forum 4 03-15-2006 01:53 PM
Transgo shift kits: where to get and P/N? ZJ_Grand ZJ Grand Cherokee Forum 4 07-10-2005 01:42 AM
