torx screws on the PCM.... - JeepForum.com
post #1 of 11 Old 06-07-2008, 08:40 PM Thread Starter
wrestlerobx
wrestlerobx's Avatar
so i read on another forum that on a Zj on the PCM that there are two torx screws that hold the case on and they are 1/2" and if they are replaced with 1/4" torx screws that they can solve an intermittent stalling problem that i am having and am under the impression it is electrical related
wrestlerobx is offline
post #2 of 11 Old 06-07-2008, 08:51 PM
Virmagicus
Virmagicus's Avatar
? Never heard that one before. link ?
Jeff
Virmagicus is offline
post #3 of 11 Old 06-07-2008, 09:00 PM Thread Starter
wrestlerobx
http://forums.cnet.com/5208-7811_102...490641#2490641
there it is IDK if it will work im going off shore fishin and am not available to wrk on my jeep till late sunday or early monday but ill let yall know if this freeby helps for all that need this fixed also if it wrks ill make a write up cuz ive spent well over $250 to not have it wrking right yet after 4 months
it is mentioned somewhere else that it makes sense this problem would happen b/c as the jeep gets older the PCM gets heavier and pulls down on the torx bolts until it causes a short, but idk like i said ill keep yall posted but first what do yall think
post #4 of 11 Old 06-09-2008, 11:55 AM Thread Starter
wrestlerobx
not the same for a 95
post #5 of 11 Old 06-09-2008, 12:51 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Your fix may be a bit different than what is indicated in that thread. 96 was when DC switch to an ODBII system, so the computer is totally different.
Have you checked the CPS?
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 11 Old 06-09-2008, 10:15 PM Thread Starter
wrestlerobx
nah i havent checked the crankshaft sensor but the camshaft sensor is good
post #7 of 11 Old 06-09-2008, 11:58 PM
nashmd454
nashmd454's Avatar
I had 3 screws on mine.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #8 of 11 Old 06-10-2008, 12:06 AM Thread Starter
wrestlerobx
yeah i have three holding it to the firewall but they arent the torx screws that would short it out like the 96 has
post #9 of 11 Old 06-12-2008, 07:02 PM
chrinee
1990 XJ Cherokee
I have a '90 jeep cherokee with the same engine quit problem. I have been trying to find out more about where this pcm is located, but haven't been able to find out what that is or where it is, can anyone explain this to me? Any info is greatly appreciated. Thanks! Renee.
chrinee is offline
post #10 of 11 Old 07-21-2019, 08:10 PM
ughjeepdontwork
We read that they are Torx T15 with standard sheetmetal-screw thread pitch. We're gonna try the 1/4" trick next weekend. Wish us luck!
ughjeepdontwork is offline
post #11 of 11 Old 07-22-2019, 08:32 PM
KiloWatts
KiloWatts's Avatar
This doesn't actually solve the issue. The issue is with the PCM header at the solder joints. When you remove the screws and replace them with shorter screws, you allow the header to flex a bit more, which temporarily creates a better connection, but the solder joints are still cracked and it will eventually fail again. The real repair is to take it apart and reflow the header connections.
Read here: https://www.cnet.com/forums/discussi...-fixed-599568/
1996 4.0 L6 RWD
KiloWatts is offline
stereo mounting screws chrisstromberg ZJ Grand Cherokee Forum 5 05-06-2008 08:38 AM
Need screws for window regulator bigdawgz28 ZJ Grand Cherokee Forum 3 05-01-2008 10:07 AM
OEM screws for dash tweeters? batninja ZJ Grand Cherokee Forum 4 09-18-2006 02:28 PM
IAC T25 Screws... chadburgwald ZJ Grand Cherokee Forum 7 09-12-2006 09:13 PM
screws from hell Arkansas_WJ ZJ Grand Cherokee Forum 16 12-05-2005 03:11 PM
