T case swap question - JeepForum.com
post #1 of 6 Old 06-08-2010, 10:46 PM Thread Starter
DIRTYDAWG98
I just got my np242j case and driveshaft from the boneyard for 200 bucks. I'm swaping out my 249.( 98 gc with a v8 and bad 249 ) now with all my reading this should just be a simple swap, just take one case and driveshaft out and put the other one in. My question is what else am I going to need? (parts wise)
DIRTYDAWG98 is offline
post #2 of 6 Old 06-08-2010, 11:18 PM
ShantasticZJ
ShantasticZJ's Avatar
You might have to get either the donor drive shaft lengthened, or your current one shortened and inch or so. (that's what happened to me.)
The only things swapped over on mine were the bezel and the tc. Had my ds shortened, adjusted the shifter linkage and it was good to go. A couple days later I did the plug swap behind the vic so it would light the right lights up for the 4wd modes.
Did you grab a 242 bezel for the shifter? What year did the 242 come out of?
-Shann
Originally Posted by gaTJgal View Post
LOOK!!! I escaped the kitchen!!!!
HERS: 98 5.2 ZJ Loredo. 249 to 242 Swap. Skyjacker Hydro shocks, Painted Canyons, Bedliner on the rocker panels. Front tow hooks. 2" Budget Boost. 31" SXT a/t.
. De-striped, roof rack, 31" BFG's. Lifted with 3" rusty's coils, s-10 bastard pack, Rancho shocks up front, and F-150 shocks in back.
Theirs: 85 XJ 2dr 5 speed, v6, junkyard build trail rig/project
1986 F-150 The Purple Beast! 300 I6, tow package, granny stick, 3" body lift and 35" wild country's
ShantasticZJ is offline
post #3 of 6 Old 06-09-2010, 06:36 AM Thread Starter
DIRTYDAWG98
I thought I wouldn't have to get it cut(the driveshaft) I was told it would match up, maybe I was misinformed?
post #4 of 6 Old 06-09-2010, 08:46 AM
LordHobbit
LordHobbit's Avatar
LordHobbit is offline
post #5 of 6 Old 06-09-2010, 03:04 PM Thread Starter
DIRTYDAWG98
I have searched and found nothing directly pertaning to the driveshaft,if I'm missing something please tell me where I can find it.
post #6 of 6 Old 06-09-2010, 04:19 PM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
The tail section of the 242 may be different than your current 249, AND the 242 most likely came out of a ZJ with an I6. This I6 would have a D35 and thus a shorter pinion than your 98 V8 and d44a axle.
The rear drive shaft length can vary because of the above.
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
249 - 242 transfer case swap ... VIC question airtraffic ZJ Grand Cherokee Forum 15 11-15-2009 12:09 PM
zj t-case swap question worsrider4047 ZJ Grand Cherokee Forum 1 09-22-2009 07:52 PM
question about transfer case swap DIRTYDAWG98 ZJ Grand Cherokee Forum 1 06-30-2009 09:47 PM
t-case swap question.. vansskaterfreek ZJ Grand Cherokee Forum 2 02-16-2009 09:11 PM
t-case swap question just jeepin ZJ Grand Cherokee Forum 3 12-16-2003 08:55 AM
