Sway bar links length? - JeepForum.com
post #1 of 6 Old 06-13-2019, 04:44 AM Thread Starter
Wolfeman1992
Wolfeman1992's Avatar
1994 ZJ
94 zj on ~4" how long of links do I need front and rear? Going for junkyard mods here I'm thinking ford explorer front links for the rear, and I was wanting to run a WJ sway bar in the front
Wolfeman1992 is offline
post #2 of 6 Old 06-13-2019, 06:51 AM
Timo_90xj
Timo_90xj's Avatar
Front swaybar needs to be at about a 5...15 angle up when looking from the side.
Rear swaybar needs to be at an angle that works correctly with minimal swaybar endlink bushing bind at ride height.
With a lifted Jeep, I highly suggest buying adjustable quick disconnects. If you use WJ front swaybar, you need to check the DIY mods required for it. It is not a direct bolt-on, but it is a fairly simple mod.
***Under construction***
Timo_90xj is offline
post #3 of 6 Old 06-13-2019, 06:54 AM
firebane
Swapping to a WJ bar isn't really worth it.
Between having to make some mods and changes it also changes the mount points for sway bar end links;.
firebane is offline
post #4 of 6 Old 06-13-2019, 08:21 AM Thread Starter
Wolfeman1992
1994 ZJ
I looked at the write up the only "mod" is drilling a new hole
post #5 of 6 Old 06-13-2019, 08:23 AM
firebane
And then finding sway bar end links that will properly work. Hole mounts are 90 degrees compared to zj.
firebane is offline
post #6 of 6 Old 06-13-2019, 08:23 AM Thread Starter
Wolfeman1992
1994 ZJ
Kinda broke atm but I need it streetable in the next 2 days otherwise I would just buy a set of adjustable links, the rear I think explorer front links are the right length
