So I've had this problem pop up once when we had subzero temps and it hasn't happened again until yesterday.
I noticed that my right turn signal indicator on the dash is slightly lit. Just enough to see that the arrow is there and looks as if it fades in. Trying to do some trouble shooting i have found that :
-only starts once either turn signal has been triggered.
-stays dimly lit until either the headlight switch is turned off, or the right signal is indicated.
-If the headlight switch has been turned off, the cycle starts again but if i stop it using the turn signal it will eventually light up on its own again.
-it stays dimly lit when the left one is flashing.
I do have a problem with my headlight switch diming the lights where the knob is (been there for about a year). the slider part is fine and stays lit all the time.
Also the left marker light has been out since... god knows when haha. all other lights work.
Any ideas of what it could be or where to start?? I hate electrical.. and it could be at least 5 different things.
I have a new headlight switch and Turn signal switch just never got around to putting them in.
I was going to order a new flasher just to keep around anyways.
Grounds are probably another thing to check.
Any ideas are greatly appreciate!!:grin2:
--1998 ZJ 4.0--
--1998 ZJ 4.0--
