steering wheel radio controls - ZJ - JeepForum.com
post #1 of 10 Old 11-10-2005, 07:11 AM Thread Starter
mailforjon
mailforjon's Avatar
2005 WK
anyone know if the steering wheel mounted radio controls will plug into a laredo with the infinity system? saw a set on ebay and was interested....maybe.
mailforjon is offline
post #2 of 10 Old 11-10-2005, 07:41 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
The "steering wheel controls" control the FACTORY radio head unit's channel, search, & volume. It does so through the body control module (BCM) with the signals carried on the chrysler collision detection (CCD) network. I would bet the wire harness for your Larado has the necessary connectors so that the controls from a similar year model would plug in. the FACTORY head unit must also be plugged into the network (a two wire plug with twisted pair wires) to recieve the signal from the BCM.
HTH
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #3 of 10 Old 12-17-2005, 11:24 AM
FrankTheTank
Guest
so is it possible to install a new stereo head unit into my jeep and still be able to some how re hook up the steering wheel volume and radio control?
FrankTheTank is offline
post #4 of 10 Old 12-17-2005, 05:31 PM
PlatinumZJ
PlatinumZJ's Avatar
Only if it is a original factory OEM unit with that capability. OR, you can get head unit with a wireless remote and a gizmo to interface from the steering wheel contorls to the IR pickup on the head unit such as the PAC SWI-X. here is a review http://www.pricegrabber.com/rating_g...7943/id_type=M
Doug
Links:
for ZJ & WJ stuff,
post #5 of 10 Old 12-17-2005, 06:26 PM
zjay
I'm not sure if the wiring is there, it would need to be checked against a wiring diagram, but I'd bet you'd at least have to change the clockspring. Usually when I get one for a customer I need to know if it has the controls or not.
96 GC Limited V8 245,000 miles Scrapped
04 GC Limited 4.0 264,000 miles
96 GC 4.0 175,000
zjay is offline
post #6 of 10 Old 12-17-2005, 07:00 PM
PlatinumZJ
PlatinumZJ's Avatar
According to the directions in the package one has to cut a wire from the switches and splice in the wire from the SWI-X, However, I have yet to complete the install - its too cold and I don't have the time to figure out which wire to cut now.
Doug
Links:
for ZJ & WJ stuff,
post #7 of 10 Old 12-17-2005, 07:55 PM
CurtP
Most 96-98 ZJ's already have the wiring in place - it's just plug-n-play. There are some OEM radios that don't interface with the CCD - you should be fine if the radio is the AM/FM/Cassette/CD player w/3-band EQ.
I've installed a 98 5.9 steering wheel in my 96 and everything worked fine. I may end up with an extra steering wheel with radio controls that will be available for someone looking for one. It will probably be 2-3 weeks though.
CurtP is offline
post #8 of 10 Old 12-17-2005, 10:58 PM
Meerkat
HTH
Doug, I am so proud!
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #9 of 10 Old 12-18-2005, 12:12 PM
PlatinumZJ
PlatinumZJ's Avatar
Cat Fancier?, Who Day?
So, Is it true. Do i win the bet?
HTH (purloined from Warren)
Doug
Links:
for ZJ & WJ stuff,
post #10 of 10 Old 06-10-2021, 04:45 PM
nam3l3ss
Hi. Anybody knows the part number of the stering wheel buttons for the radio? Thanks
Sent from my SM-G970F using Tapatalk
nam3l3ss is online now
Steering wheel radio controls??? Rod Mowery ZJ Grand Cherokee Forum 13 07-11-2020 08:55 AM
Radio controls on steering wheel.... kwb18 ZJ Grand Cherokee Forum 1 08-21-2009 04:44 PM
Adding Steering Wheel Radio Controls on WK Laredo JeepGRsrr WK Grand Cherokee & XK Commander Forum 20 06-04-2009 03:58 PM
ZJ remote radio controls (steering wheel) - help? mailforjon ZJ Grand Cherokee Forum 5 01-14-2006 09:43 AM
Radio steering wheel controls...... 2000 Sienna ZJ Grand Cherokee Forum 2 10-06-2004 11:48 AM
