Steering column interferes with ignition - JeepForum.com
 1Likes
  • 1 Post By Timo_90xj
post #1 of 2 Old 05-02-2019, 10:34 AM Thread Starter
BlueMagnus
BlueMagnus's Avatar
1997 Grand Cherokee 4WD V8
As my vague title eludes to, for some reason my steering column will prevent me from starting. Example; for the first weeks I had the jeep, my ignition fuse kept blowing and my starter would get stuck. I replaced the starter and cleaned the contacts. I thought the issue was fixed until my new starter did it again. Blew out the fuse after a few bad attempts. Then I found out through trial and error that it will start no problem if the wheels point left. If the wheel is straight or to the right, dead. When I got the jeep there was no ground for the column, horn would not work. I grounded it, also the fuse issue was happening before the horn thing was fixed. So what the hell could it be?
BlueMagnus is offline
post #2 of 2 Old 05-02-2019, 01:07 PM
Timo_90xj
Timo_90xj's Avatar
I'd remove the plastic trim around the steering column and check the wiring first. Make sure no wire harnesses or wires are resting on the steering column under the dash.
riverzj likes this.
***Under construction***
Timo_90xj is offline
87 YJ steering column install kstchubs YJ Wrangler Technical Forum 9 04-23-2019 10:11 AM
Help Identify Part In XJ Steering Column Ignition wheels082 XJ Cherokee Technical Forum 6 02-10-2019 12:31 PM
question about airbag light catfishman XJ Cherokee Technical Forum 10 11-11-2018 04:52 PM
Chasing Gremlins Nereussailor Jeep CJ Forum 11 09-01-2018 06:41 AM
Aftermarket Steering Column - Key wont turn tibado Jeep CJ Forum 9 08-28-2018 10:12 PM
