Someone confirm lift height? - JeepForum.com
 2Likes
  • 2 Post By LordHobbit
post #1 of 9 Old 01-25-2020, 02:32 PM Thread Starter
jcjunkie
jcjunkie's Avatar
I was told I had a six inch lift. 3" coils and 3" spacers..
I measured the spacers they do measure 3".
However, my front hub to fender is 21 1/2".. factory 5.9 v8 is 17-18"? That would mean I only had a 3" lift correct?
98 5.9
jcjunkie is offline
post #2 of 9 Old 01-26-2020, 08:54 AM
Timo_90xj
Timo_90xj's Avatar
Yeap, roughly 18" from center of wheel hub to bottom of fender flare.
***Under construction***
Timo_90xj is online now
post #3 of 9 Old 01-26-2020, 12:34 PM Thread Starter
jcjunkie
jcjunkie's Avatar
So it's in fact prob factory coils with just a 3" spacer.
I'm not a fan of spacers. In fact one is has a split in it. If I keep the same height, wouldn't it better to get 3.5" coils and then an isolator or is isolators needed?
98 5.9
jcjunkie is offline
post #4 of 9 Old 01-26-2020, 11:33 PM
Mr. Puddles
Do you still have the factory short arm suspension?
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #5 of 9 Old 01-27-2020, 05:36 AM Thread Starter
jcjunkie
jcjunkie's Avatar
No I have full adj control arms, and adj front track bar.
98 5.9
jcjunkie is offline
post #6 of 9 Old 01-27-2020, 09:26 AM
LordHobbit
LordHobbit's Avatar
coils are always better. With the adjustable arms, you are that much ahead. Make sure you have double sheer adjustable track bar in front and rear.
Isolators are needed, I'd get new ones if I were you. Hit up Kolak (PM here or [email protected]). He'll have the new isolators and a great deal on coils for you.
GChief and Tomcorr like this.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #7 of 9 Old 01-27-2020, 10:30 AM Thread Starter
jcjunkie
jcjunkie's Avatar
thank you for a very good response. I think I'm going to do a front to rear swap and just get new three and a half inch coil for the front and a few isolators. I have a front adjustable track bar but I don't believe it has a double shear bracket it looks like the factory bracket. So should I just buy a new bracket for the front and that should be good?
98 5.9
jcjunkie is offline
post #8 of 9 Old 01-27-2020, 02:11 PM
Mr. Puddles
Sorry I should have asked that different. Do you have a short or long arm suspension?
Follow the build!
post #9 of 9 Old 01-27-2020, 03:16 PM Thread Starter
jcjunkie
jcjunkie's Avatar
Short arms
98 5.9
jcjunkie is offline
