Shock mount popping - JeepForum.com
 5Likes
  • 1 Post By KiloWatts
  • 3 Post By Timo_90xj
  • 1 Post By zjosh93
post #1 of 9 Old 07-29-2021, 09:02 AM Thread Starter
KiloWatts
KiloWatts's Avatar
Shock mount popping
Has anyone ever experienced this? I have a popping sound coming from the top of the shock mount. There is no sound with the shock disconnected from the bottom and hanging. But when it is all connected and pressure loaded it pops when moving up and down. Makes all sorts of noise whole driving, and I can replicate it by bouncing that side (passenger) up and down. Is there some metal popping in there somehow? Or could it be the shock itself? Everything's tight up top.
Sent from my Pixel 5 using Tapatalk
KiloWatts is offline
post #2 of 9 Old 07-29-2021, 09:25 AM
HighLonesome
HighLonesome's Avatar
It may be flopping about sideways. And that may have wallowed out the hole. Or the bushings could just be shot.
try these, I think they were used for UC ZJs, but not sure, they work well
https://www.4wheelparts.com/p/1990-J...?ppcfon=1&gp=1
HighLonesome is offline
post #3 of 9 Old 07-29-2021, 09:38 AM Thread Starter
KiloWatts
KiloWatts's Avatar
Thanks, I figured it out. The fix: Take off the shock and put it back on.
Just kidding, I think maybe the top bolt was just hitting the frame in the hole. Like you said, flopping about
Should be centered in the hole.
HighLonesome likes this.
post #4 of 9 Old 07-29-2021, 11:06 AM
HighLonesome
It may keep doing it. Working it's way off center that is.
post #5 of 9 Old 07-29-2021, 11:29 AM Thread Starter
KiloWatts
KiloWatts's Avatar
Yeah it is. How annoying, heading to the parts store now
post #6 of 9 Old 07-29-2021, 11:39 AM
HighLonesome
The metal bushing retainers should be wider than the bushing in circumference.
post #7 of 9 Old 07-30-2021, 04:01 AM
Timo_90xj
Timo_90xj's Avatar
Play rock and heavy metal louder in your Jeep. It'll make that annoying pop go away.
I suggest ZZ Top in memory of Dusty Hill.
***Under construction***
Timo_90xj is offline
post #8 of 9 Old 07-30-2021, 07:29 AM
zjosh93
In that first pic the cup washer is upside down. The washer cups the bushing. That's why the bushing is pushed so far out.
zjosh93 is offline
post #9 of 9 Old 07-30-2021, 08:01 AM Thread Starter
KiloWatts
KiloWatts's Avatar
I'll be danged, it is. Still popping, so it's wasn't the hole. Starting to wonder if it's coming from inside the shock, if that's even possible. I'm taking @Timo_90xj 's advice for now.
