Shifting issues after changing Neutral Safety Switch? - JeepForum.com
 1Likes
  • 1 Post By wsc803
post #1 of 5 Old 03-15-2020, 02:54 PM Thread Starter
wsc803
Specs: 98 ZJ Limited, 4.0 I6, 200k miles
I changed my Neutral Safety Switch yesterday because my reverse lights weren't working. I used the guide in this post: https://www.jeepforum.com/forum/f13/z...epair-3435370/
Everything went great. No ATF even came out (checked levels afterward and they're where they should be) when I removed the NSS. Reverse lights work now! Awesome, time for a beer.
...except I drive it today and I seem to have some shifting problems (or, at least, shifting is different). It seems to shift into 2nd earlier than usual (~15mph/2000rpm) with a little hiccup. Feels like it's slipping, I lose a little power, RPMs drop a few hundred, then spike a few hundred, then return to normal. I don't think there are any issues shifting into 3rd, 4th, or OD. I could be getting into my own head, but it also feels like the accelerator is much more sensitive.
It was certainly shifting much later before I changed the NSS. Of course I'm worried about potential tranny issues because I just hit 200k.
The NSS I used was just the basic one from Advance. It was a spur of the moment thing to do some Jeep work and I didn't want to wait on one in the mail. Should I just order a Mopar one?
wsc803 is offline
post #2 of 5 Old 03-16-2020, 04:21 AM
Timo_90xj
Timo_90xj's Avatar
NSS has nothing to do with shifts, all it does is provide backup lights when in reverse, and allows you to start when in neutral or park.
This is a separate issue, and might just be coincidence it started now, or you might've knocked loose your throttle valve cable.
***Under construction***
Timo_90xj is offline
post #3 of 5 Old 03-19-2020, 03:10 PM
mikem350
1994 ZJ
I second the TV cable!
Proud owner of two DD 4.0 ZJs
Flame Red 94 mint!
Silver 98 just hit 320k miles....runs great!
mikem350 is offline
post #4 of 5 Old 03-20-2020, 08:53 AM Thread Starter
wsc803
Thanks! I gave a look at the TV cable a few days ago and the little white clip is gone. So... that's probably it.
Time to grab one out of the junkyard... if they're still open with all this COVID-19 stuff.
1996maroonzjf likes this.
wsc803 is offline
post #5 of 5 Old 03-20-2020, 09:30 AM
Timo_90xj
Timo_90xj's Avatar
You might want to order a new one from Rockauto, the cables stretch and can cause erratic shift behavior - costs only around 50$ and it's a Mopar part
