Rough Cold Idle - JeepForum.com
 2Likes
  • 1 Post By Timo_90xj
  • 1 Post By jtec
post #1 of 7 Old 02-21-2020, 07:13 AM Thread Starter
paulvon
Rough Cold Idle
On my 97 ZJ 4.0 the idle is rough and it is temperature dependent.
50 deg F starts without issue
40 deg F starts but seems like it wants to stall
30 deg F have to give it gas to prevent stalling
Jeep runs fine after it has fully warmed up.
Currently there are no codes or pending codes.
A few months ago replaced the idle air controlled and cleaned the throttle body.
This is a new behavior. Worked fine earlier in the winter.
Could it be the IAC again just without a code or something else?
Sent from my SM-G920V using Tapatalk
1997 ZJ 4.0 L - Upgraded to heavy 93 sway bar
2004 WJ 4.7 L - 2 1/2" lift
2011 KK 3.7 L
paulvon is offline
post #2 of 7 Old 02-21-2020, 09:34 AM
Timo_90xj
Timo_90xj's Avatar
I'd suspect coolant temp sensor and/ or intake air temp sensor.
On a 1997 you can easily check those with a code reader that supports live mode; when the engine hasn't been started -> plug in the reader -> turn ignition key to run (key on, engine off) -> check in the live mode what the intake air temp and coolant temps show.
jtec likes this.
***Under construction***
Timo_90xj is offline
post #3 of 7 Old 02-27-2020, 06:18 AM Thread Starter
paulvon
Have been checking the temps for the past few days and everything looks fine.
Still having the idle issue.
2011 KK 3.7 L
paulvon is offline
post #4 of 7 Old 02-29-2020, 10:05 AM
8v-of-fury
30f isnt even cold, and no (gasoline) EFI should have a problem starting at that temp.
The fact that it starts better warmer gives us an idea that it is not over fueling.. as that would help when colder.
When you pedal in some throttle (air) does it run proper?
Basically it takes a real world temp from the CTS or IAT to give itself a base fuel map to start with. That's an odd one.
Both those sensors show cold what the actual outside temps are?
'98 ZJ 4.0/242, Locked d30/d35, 31x10.5x15, 2" BB w/ Bilstein 5100's
8v-of-fury is offline
post #5 of 7 Old 02-29-2020, 10:20 AM
Timo_90xj
Timo_90xj's Avatar
Did you check the live data from the OBD2 port with a code reader? How did the temperature sensor temps - we need to know BOTH the coolant and intake air temps - look like in relation to outside air temp and engine running a while?
We also need to know what the coolant and intake air temps are BEFORE you fire up the Jeep and what the outside air temperature is at the same time.
These things fire up and idle like nothing at -25F and way colder than that, I know from personal experience. Since your issue is outside temperature- related, it must have something to do with how the PCM tries - or in this case does not - adjust to different temps.
post #6 of 7 Old 02-29-2020, 12:32 PM
jtec
jtec's Avatar
2014 JK Wrangler
A scanner makes quick work of diagnosing I would also look at fuel trims and o2 readings.
No scanner- try looking at
spark plugs, wet, BLACK, dry, tan?
What is fuel pressure PSI?
engine vacuum?
Timo_90xj likes this.
jtec is online now
post #7 of 7 Old 03-01-2020, 10:57 AM
terpsmandan
I was having an issue with the 98 4.0. When cold it would start fine but if you had to shift from reverse to drive it would stall and be very difficult to get restarted. Replaced the cap, rotor and plugs and the issue is gone. How long has it been since you replaced the cap and rotor?
terpsmandan is offline
