roof rack - JeepForum.com
post #1 of 10 Old 09-01-2006, 04:23 PM Thread Starter
footinmouth47
footinmouth47's Avatar
roof rack
Has anyone made a roof rack that is designed to fit in the back with the seats down as a shelf, with legs so that it sits above the seats instead of directly on the seat itself? Also, how deep is a normal roof rack? Also, a picture of the mounting brackets for the roof rails would be much appreciated.
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline
post #2 of 10 Old 09-01-2006, 04:43 PM
Swamp Boy
Swamp Boy's Avatar
???????????????? Roof rack that sits inside with Legs????
Just another soccer moms Grocery getter....
Swamp Boy is offline
post #3 of 10 Old 09-01-2006, 11:20 PM
user jeep
Guest
interesting...
user jeep is offline
post #4 of 10 Old 09-02-2006, 05:50 AM
driabyor
driabyor's Avatar
1994 ZJ
I have some cheapie 2 ft by 2 ft plastic shelves that I put in the back.
It makes getting to stuff a lot easier. They fit just right. whne they are in there I can still get my spare out without moving them.
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #5 of 10 Old 09-02-2006, 06:33 AM
Phil Gerard
Former Mod
Phil Gerard's Avatar
Before we all go nuts here let's have some definitions:
Roof Racks - They go on the roof.
Interior Racks - They go inside the GC.
OK - go at it!!!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #6 of 10 Old 09-02-2006, 07:08 AM Thread Starter
footinmouth47
Exactly! I would like a multi-purpose rack, one that sits on the roof then can have legs easily attached or folded out to sit in the back as a shelf. So i would like to know some of the more popular measurements for a rack that still could be slid into the back. Mind you, I have no spare tire and when I get one it will be on the rack. Thank you for any help.
Greg
post #7 of 10 Old 09-04-2006, 09:25 AM Thread Starter
footinmouth47
so no one has ever thought of this or tryed it?
Greg
post #8 of 10 Old 09-04-2006, 12:29 PM
doyll
Greg
I guess not.
I've designed and am about to build 3 units that will fit in behind front seat. One will be behind back seat when seats are up. Other 2 will be sized to fit on back seats when folded down. Different sizes so one is size of each seat and will allow other side of seat to fold up and down. Their heigth will be below window level and will be strong enough to lay on. I will be able to use them as a bed when needed. The back one will have full extension drawers. Bottom drawer will be deep enough for tire to fit in. Areas on sides will have removable covers to access them. The 2 that set on back seats when folded will have side door and top access. They can be set on top of back one when seats are in use. I figure this way I will be able to secure everything I carry... all camping gear, 4x4 gear and parts, and whatever else I need when in the sticks. And when I have to travel a long distance to get somewhere, can put extra luggage on top of it too.
I've also designed a low wind resistant rack for the top by using 4 stock roof rack rails and mounting tubing on top of them lengthwise. This will give me a 38" x 72" rack.
1997 ZJ 4.0, 42re, 242, 3.73, tow hooks, reciever hitch, skids, OBA, F>R lift, Rancho 9000s, Addco 1.25", JKS discos, 265/75r MTs on stock wheels, 99+ intake, Banks look-alike header, sliders,
NEED: adjustable upper front control arms, front track bar frame bracket for JKS/RE bar, adjustable rear track bar, Addco rear sway bar, winch
doyll is offline
post #9 of 10 Old 09-04-2006, 12:56 PM
driabyor
driabyor's Avatar
1994 ZJ
so if and when the dual rack is made .. Where will the spare then go.. If you had it on the rack. it would then have to be on the inside also
5.2 liter 242 :)
driabyor is offline
post #10 of 10 Old 09-05-2006, 12:41 PM Thread Starter
footinmouth47
right it would be put inside with the rack for windresistance reasons (mpg).
Greg
Need some help with my roof rack suzieque WK Grand Cherokee & XK Commander Forum 8 03-25-2009 01:35 PM
ZJ Roof Rack Steve98 ZJ Grand Cherokee Forum 19 12-08-2007 09:34 AM
GC Roof Rack 51flattie WK Grand Cherokee & XK Commander Forum 9 05-21-2007 10:20 PM
Durable Roof-rack vs. Trailer-hitch Rack? DenverCruiser ZJ Grand Cherokee Forum 12 01-10-2006 03:58 PM
