Roll Call - Whose VIC is still working? - JeepForum.com
 11Likes
post #1 of 72 Old 06-25-2019, 09:17 PM Thread Starter
KiloWatts
KiloWatts's Avatar
I'm just curious as to the lifespan of these things. I've had 2 now that have blown up, and I know many, many others have too. So, whose VICs are still working? And did you do any repairs to them?
1996 4.0 L6 RWD
KiloWatts is offline
post #2 of 72 Old 06-25-2019, 09:33 PM
1996maroonzjf
1996maroonzjf's Avatar
No issues with mine after reflowing the “low coolant” pin. It even told me when one the the three bulbs was burnt out in the third brake light a few weeks ago.
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is online now
post #3 of 72 Old 06-25-2019, 09:40 PM
firebane
100% working with zero issues
Except for the annoying beeps I get from low coolant sensor, low washer fluid and low fuel.
firebane is offline
post #4 of 72 Old 06-25-2019, 11:10 PM
Nick-B
I've had the same experience as Tim above. Had to resolder a few points to fix the "low coolant" alarm. Works 100% now. 212K miles on my ZJ.
Regards, Nick
'97 ZJ Grand Cherokee Laredo, 4.0
'90 XJ Cherokee Limited, 4.0 (SOLD)
Nick-B is offline
post #5 of 72 Old 06-26-2019, 03:18 AM
Timo_90xj
Timo_90xj's Avatar
Yeap, I gotta reflow my VIC as well, but other than that it's working 100%. Factory original from late-1997.
***Under construction***
Timo_90xj is offline
post #6 of 72 Old 06-26-2019, 03:28 AM
riiz
riiz's Avatar
100% working VIC in my 1996 Laredo ZJ. Granted the jeep just hit 69k miles the other day.
mikem350 likes this.
riiz is offline
post #7 of 72 Old 06-26-2019, 07:01 AM
BlaketheSnake
BlaketheSnake's Avatar
So far mine is still working. I've not had any issues.
For Great Deals and Customer Service on your Jeep, Drop Nick a Line!
Kolak Performance
Tread lightly or we all will be tree hugging hikers!
2006 LJ Rubicon Black 33 BFG, 3.5" Metal Cloak
1998 ZJ 5.2V8 Deep Pearl Slate w/Up Country Suspension
1988 SJ416 White
BlaketheSnake is offline
post #8 of 72 Old 06-26-2019, 09:42 AM
DirectMatrix
Mine is original 1994 with 87k on the clock. Doesn't work. I pulled 2 out of the junkyard in the last 6 months. Also not working.
I even went as far as replacing all of the capacitors, but I wasn't too diligent with my soldering and have a crossed connection somewhere. When I plug in my VIC, a component starts smoking. I'll troubleshoot eventually.
The long and short of it is, they aren't very robust and will eventually need some TLC. Or do what many have done and replace it with a bin/organizer or some kind
92 YJ, Delilah
DirectMatrix is offline
post #9 of 72 Old 06-26-2019, 10:26 AM
GChief
Junior Member
GChief's Avatar
95 with 75k, all original and works great.
Thanks Rob
GChief is offline
post #10 of 72 Old 06-26-2019, 01:24 PM
MaintMech
Old and in the way
MaintMech's Avatar
Did the reflow and it's still running fine. 133K Miles.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #11 of 72 Old 06-26-2019, 01:52 PM
wkbear
wkbear's Avatar
228K miles and mine works. Just get the 4WD indicator problem since I swapped to a NP231.
1995 Grand Cherokee Ltd., 5.2, 249, stock (for now)
wkbear is offline
post #12 of 72 Old 06-26-2019, 03:12 PM
Boone96ZJ
the one in mine when I bought it wouldn't even come on, after cracking it open it looks like someone threw their entire cup of coffee or coke on the circuit board. Stole one from a 5.9 in a junkyard and reflowed every pin and worked great since 2013.
96 5.2 242 3" 32x11.5
https://www.jeepforum.com/forum/f13/1996-grand-cherokee-laredo-5-2-a-2570290/
Boone96ZJ is offline
post #13 of 72 Old 06-26-2019, 03:27 PM
Benthal8
Benthal8's Avatar
I haven’t done the reflow on mine yet but funny thing is after seeing “coolant sensor bad” a gazillion times, one time the coolant level was low and the VIC told me about it right away!
I tapped this out using Tapatalk
Benthal8 is offline
post #14 of 72 Old 06-26-2019, 05:15 PM
FlamingRain
Both of my ZJ's I've owned have had "Coolant Sensor Bad" but also correctly displayed Coolant Level Low, so I'm sure mine needed to be reflowed, but have not totally blown up.
Benthal8 likes this.
2wd can really get you places you can't get out of without 4lo. - Ratmonkey
FlamingRain is offline
post #15 of 72 Old 06-26-2019, 06:47 PM
firebane
Low coolant is a bad sensor in the overflow. I've pulled mine and blocked the hole. Either my zip tie job is bad or I need to install the resistor.
firebane is offline
