Reputable place to get a remanufactured PCM for 1998 Jeep Grand Cherokee Laredo - Page 2 - JeepForum.com
post #16 of 18 Old 05-31-2016, 10:05 AM
MrRoundel
I suspect that this procedure is the same as guys who work on vacuum-tube sockets in guitar amps, etc. They use a pick to close the female contact diameter in order for them to fit tighter around the pins. They work the pick behind the contact, and lever it in towards the center, thereby decreasing the diameter, and tightening the fit. It's easier than expanding the pins.
It's good to know that it's probably not advisable to remove and replace the PCM plugs from the PCM any more than absolutely necessary.
MrRoundel is offline
post #17 of 18 Old 05-31-2016, 11:47 AM Thread Starter
dsiglin
Found it:
https://www.jeepforum.com/forum/f13/i...l-fix-1487443/
I'll give it a read and that other thread a like.
dsiglin is offline
post #18 of 18 Old 06-04-2016, 07:21 AM Thread Starter
dsiglin
Hey so about that dielectric grease. Will that hurt to use it and if not where should I put it?
dsiglin is offline
pcm
