Remote oil filter - JeepForum.com
 6Likes
post #1 of 29 Old 12-03-2019, 08:30 AM Thread Starter
Wolfeman1992
Wolfeman1992's Avatar
1994 ZJ
Remote oil filter
Just a random thought, would a s10/blazer factory remote filter mount work on our Jeeps? If so which engines?
94 ZJ 4.5" on 31s
Wolfeman1992 is offline
post #2 of 29 Old 12-03-2019, 08:51 AM
LordHobbit
LordHobbit's Avatar
You can get remote filter adapters for your Jeep.
93 red ZJ 196k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #3 of 29 Old 12-03-2019, 09:09 AM Thread Starter
Wolfeman1992
1994 ZJ
Thanks for answering, it was just a random thought but good to know it'll work
94 ZJ 4.5" on 31s
post #4 of 29 Old 12-03-2019, 11:54 AM
Mr. Puddles
94 ZJ 4.5" on 31s
I recently installed a transdapt unit. Im working through oil leak issues now. ALL the fitting and plugs leaked right from the start even using copious amounts of teflon tape.
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #5 of 29 Old 12-03-2019, 12:05 PM
Mr. Puddles
This is the kit I used.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I did also need to get an extra filter thread adapter as one is used to attach the adapter to the block
eventually I would like to do a round oil cooler (not sure the exact name) like this
https://www.summitracing.com/parts/sum-331000/
Follow the build!
post #6 of 29 Old 12-03-2019, 12:05 PM Thread Starter
Wolfeman1992
1994 ZJ
Orings maybe?
94 ZJ 4.5" on 31s
post #7 of 29 Old 12-03-2019, 12:36 PM
Mr. Puddles
I beieve the leak in the factory adapter was due to wear and/or damage to e mating surface. The only oring in this kit is the adapter to the block. All the barb fittings and pipe plugs are teflon taped and all leak. I need to make time to call Transdapt. In the mean time I am on the hunt for some TiteSeal (aviation sealant putty). Its hands down the best sealant I have ever used.
Follow the build!
post #8 of 29 Old 12-03-2019, 01:49 PM
zjosh93
Looks like the GM 4.3 remote cooler adapter won't work on our engines. Those GM engines use an oil filter adapter that attaches with two bolts from the factory, and the remote adapter bolts to that location with two longer bolts.
My turbo car has had an oil cooler sandwich adapter on it since it left the factory (was a police car). It has never leaked. I think you might just need to get a higher quality adapter. These look good:
Moroso Adapter
Canton Adapter
Also, it looks like some of the reviews for the Trans-Dapt parts mentioned that the NPT threads weren't cut right. Might be worth a couple minutes to chase them with a tap. I also prefer the liquid teflon paste sealer to tape, but that might just be personal preference. I think it seals better and it less likely to get junk in your lines.
I also don't trust that push-loc hose for hot oil. I've heard of it failing at higher temps and pressures.
zjosh93 is offline
post #9 of 29 Old 12-03-2019, 02:08 PM
Mr. Puddles
Moroso Adapter
Canton Adapter
Transdapt says no more than 3 wraps of teflon tape. I did at least double that. Thats why Im looking at that aircraft sealant. I would prefer liquid over the tape but I was working with what i had at the moment.
I did make a rookie mistake and used 1/2 inch heater hose as the length of hose they included wasnt long enough. That ended up with me on the side of the road with 6 quarts of oil on the ground. I replaced that with 1/2 inch fuel injection hose. It petroleum rated and if I ever see enough pressure to blow it out I have bigger issues on my hands.
Follow the build!
post #10 of 29 Old 12-03-2019, 02:30 PM
zjosh93
Good deal. The issue with the push-loc hose has been that regular push-loc hose is rated to something like 200 degrees and 250 psi. But not at the same time. Pressure rating drops with temperature. I saw some racers using it for transmission hoses and have it pop off the barbed fitting when it got really hot. Push-loc barbs are sharper than normal because they are not supposed to use a clamp. If you use a clamp on them it can damaged the hose. The Trans Dapt kit you sent the link to uses push-loc hose based on the pictures.
zjosh93 is offline
post #11 of 29 Old 12-03-2019, 02:33 PM
Mr. Puddles
And I do run clamps. During the initial install and testing I had a hose blow off in the driveway. (some trial. More error)
Follow the build!
post #12 of 29 Old 12-03-2019, 02:34 PM
Mr. Puddles
BTW I have pics of all this. I have been meaning to get them updated on my build page but Ive been too busy with attempting to buy a house.
Follow the build!
post #13 of 29 Old 12-03-2019, 04:25 PM
paulvon
Had a filter that worked for a year then one of the hoses started to leak on a drive.
Make sure to keep your eye out for leaks
Sent from my SM-G920V using Tapatalk
1997 ZJ 4.0 L - Upgraded to heavy 93 sway bar
2004 WJ 4.7 L - 2 1/2" lift
2011 KK 3.7 L
paulvon is offline
post #14 of 29 Old 12-03-2019, 04:27 PM
Mr. Puddles
Her name is Puddles for a reason. If she isnt leaking shes empty
Follow the build!
post #15 of 29 Old 12-03-2019, 09:39 PM
GOLDWING
GOLDWING's Avatar
For threaded connections I use "Monster" brand PTFE tape that I buy at my local Menards. Unlike regular teflon tape, it actually is reliable for keeping leaks from happening. I get paid for no leaks, I get to do it over for free if it leaks. When a teflon paste is called for the answer is Hercules Mega-loc.
ALWAYS lube o-ring connections unless you have the time to do it twice.
GW
"The Dude Abides"
GOLDWING is offline
