Recommendations for Motor mounts and transmission mount refurbishment on 95 ZJ - JeepForum.com
 3Likes
  • 2 Post By PolkaPower
  • 1 Post By riiz
post #1 of 3 Old 05-15-2021, 11:47 AM Thread Starter
95-ZJ
95-ZJ's Avatar
1930 CJ2
Good afternoon,
I will need to eventually fix the oem header exhaust leaks and want to get my ducks in a row. 26 years of use and the stock EM shows all the typical cracks
Should I take the original and have a shop re-weld it or just entirely replace the exhaust manifold?
Planned on getting a felpro gasket and one of the flex pipe manifolds on line. Already got a Dorman exhaust and intake bolt kit but havent got new compression washers yet?
But in my search and knowledge gathering phase now, I'm seeing recommendations to remove and replace both motor mounts and the transmission mount on the 242 and there are several choices, brands, types?
Any part #s or advice, as I dont want to redo this anytime soon, id rather it be "once and done" and dont want to crack the replacement exhaust all over again by not going with a complete fix and the correct parts.
Anyone else, swap the motor and transmission mount on a ZJ in prep for exhaust manifold replacement/repair?
Suggestions, guidance, help, advice?
All is helpful. Thx
Sent from my SM-T567V using Tapatalk
95-ZJ is offline
post #2 of 3 Old 05-15-2021, 05:16 PM
PolkaPower
PolkaPower's Avatar
These will work well and ship out fast.
https://dbmetalworx.com/4x4-products...?sort=priceAsc
These are the best but most expensive and you may have to wait if he has to make them.
https://ironman4x4fab.com/collections/zj-drivetrain
I've had both. The welds and powder coating on the Ironman are really nice but the price reflects it. The DB don't look nearly as nice but they'll work just fine.
Sent from my iPhone using Tapatalk
HighLonesome and 95-ZJ like this.
PolkaPower is offline
post #3 of 3 Old 05-15-2021, 05:43 PM
riiz
riiz's Avatar
Scrap the exhaust manifold, pick up a quality header from Banks or similar. The cheap ebay headers will crack, much faster than the stock unit.
95-ZJ likes this.
riiz is offline
