Rear Trailing Arm Bottom Bushings - JeepForum.com
post #1 of 5 Old 06-10-2021, 12:40 PM Thread Starter
JonS
The metal casing on my rear trailing arm bottom bushings are severely rusted but the rubber bushings looks intact. I purchased the items below and was wondering if these have to be pressed into the trailing arms or if they just fit in place with the bolt going through? How are these replaced?
JonS is offline
post #2 of 5 Old 06-10-2021, 01:04 PM
PolkaPower
PolkaPower's Avatar
Press fit. Tighten the bolts with the vehicle on the ground or you will shorten the bushing life.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #3 of 5 Old 06-13-2021, 05:33 PM
jeepjeepster
I imagine its going to be heck to get the old ones out and the new ones in without crushing the control arm.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #4 of 5 Old 06-13-2021, 05:39 PM
PolkaPower
PolkaPower's Avatar
I've always just swapped the entire arm.
post #5 of 5 Old 06-14-2021, 01:32 AM
riiz
riiz's Avatar
You can insert a piece of wood or a socket, to stop the arm from being crushed closed.
riiz is offline
