"Rear Lamp Failure" message on VIC - JeepForum.com
 1Likes
  • 1 Post By MaintMech
post #1 of 9 Old 06-04-2019, 10:05 AM Thread Starter
TCRay
My VIC shows the message "Rear Lamp Failure" when I start up the 97 ZJ. I checked all of the tail lights, turn signals, reverse, license plate lights. All are good.
Any ideas?
I was wondering if there is a solder joint on either of the VIC circuit boards that could go bad to send that message even when all the light bulbs are good. (Like the message "Coolant Sensor Bad" when the one solder joint is bad on the bottom circuit board.)
Thanks!
TCRay is offline
post #2 of 9 Old 06-04-2019, 10:16 AM
jtec
jtec's Avatar
2014 JK Wrangler
you are using correct bulbs?
Did you check brake lights? I am sure but did not see mention.
Have you used tow harness lately (if applicable)?
jtec is offline
post #3 of 9 Old 06-04-2019, 11:21 AM Thread Starter
TCRay
Thanks for the reply! I did not check brake lights since I am the only one at home. I need someone to press on the pedal while I watch.
I believe the correct bulbs are in there. I think they are the 1057 bulb, if I am not mistaken. I will check.
I do have a tow harness but have not used it in about 3 months.
Thanks again!
TCRay is offline
post #4 of 9 Old 06-04-2019, 11:24 AM Thread Starter
TCRay
Something I had not thought of is the high mount brake light.
I looked up the bulbs, they are a 3057 by one websites info.
TCRay is offline
post #5 of 9 Old 06-04-2019, 12:41 PM Thread Starter
TCRay
I finally went up to O'Reilly's part store and had a man come out and watch as I put on the brakes and put it in reverse. It was a back-light bulb. All fixed. Sorry for the hassle but thank you for your reply.
BTW, the reason I was suspecting the VIC was because about 4 months ago I replaced my bulbs in the rear. Also, just this past week, the "Cooling Sensor Bad" warning appeared. So I took the VIC out, found the faulty solder point, and re-soldered it.
Now with the solder point fixed and new bulbs in back, there are no warning bells and flashes on the VIC!
TCRay is offline
post #6 of 9 Old 09-23-2021, 03:54 PM
ZJ97ACE
Thanks again!
best way to check the lights on the rear of your jeep by yourself is to park in front of a large enough window (front end facing away from window) that you'd be able to see the back of your jeep in the rear view mirror. this has worked for me on more than one occasion.
ZJ97ACE is offline
post #7 of 9 Old 09-24-2021, 08:00 PM
papitt
YES ACE IS CORRECT & I too back up to my white garage door in late evening time . Mash my brakes & check my rear view .
& I also live in the country & I have some kind of stick whether its from a tree or some building irwm.
But I ke[p something around I can place between the steering wheel & Brake pedal .. or the Seat & the BrAKE PEDAL . bUT THERE'S LOT OF WAYS TO GET A BREAK LIGHT WHEN YOUR BY YOURSELF.
papitt is offline
post #8 of 9 Old 09-25-2021, 08:54 AM
MaintMech
MaintMech's Avatar
I use a chunk of 2X4 between the seat and pedal. Trans in park of course.
Timo_90xj likes this.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #9 of 9 Old 09-26-2021, 02:09 PM
Titnado1
that would be a great fail video if it weren't in park lol
If you can drive it, fly it, or bang it.... rent it.
Titnado1 is offline
