Radiator and electric fan specs - JeepForum.com
post #1 of 17 Old 08-13-2019, 09:12 PM Thread Starter
Lkunter
1981 CJ7
Does anyone have details on the OEM radiator and electric fan for a 1998 5.9 ZJ? I'm running hot and believe I need to replace the radiator and switch back to the electric fan instead of the clutch fan that exists today. I say this as I frequently run between 115 and 130.
Lkunter is offline
post #2 of 17 Old 08-14-2019, 11:24 AM
Mr. Puddles
115-130 degrees F?
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, it’s too stupid to know it’s supposed to die.
Mr. Puddles is offline
post #3 of 17 Old 08-14-2019, 12:44 PM
Benthal8
Benthal8's Avatar
Sounds like your fan is working, I wouldn’t throw parts at it yet.
At what temp does your efan kick in?
How’s your coolant? Do you have any leaks?
Try a search in this forum for efan or e-fan in this forum. (Only the 5.9 has it) There is a replacement but I think you’re a few diagnostic steps away from that.
UPDATE: I see now that you were taking more about the switch rather than the fan itself. Two switches, low/high speed.
Unplug the switch and jump a wire across the female plug connectors, does it turn the fan on?
Benthal8 is offline
post #4 of 17 Old 08-14-2019, 01:07 PM
jtec
2014 JK Wrangler
130 Celsius (266°F) ??? a little over heating there - Maybe a new switch - I do not know off hand any test for the hose mounted switch...
radiator not restricted, all shrouds installed, Thermostat - maybe old and slow, worn Water pump,
jtec is offline
post #5 of 17 Old 08-14-2019, 01:37 PM
kg6mov
Hears the voices
kg6mov's Avatar
The clutch fan should cool better than the efan that the niner shipped with. If you don’t have the niner shroud then converting back to an efan is likely not going to be worth it for a street driven vehicle.
kg6mov is offline
post #6 of 17 Old 08-15-2019, 01:10 PM Thread Starter
Lkunter
1981 CJ7
Sorry. That would be very cold. I run between 215 and 230 and have a new 185 deg thermostat. The previous owner replaced the electric fan with a clutch fan as well as the shroud. Now it is blocked some. I have a wench and it appears there is a large after market Trans cooler. So in stop and go traffic I get up around 230 and around 215 on the highway is 95 degree heat. My concern is not only with street driving but this will be heading to the mountains next year and with high heat and a slow moving group I don't need this to overheat.
I have a company that was recommended by a friend that produces really nice aluminum radiators with electric fans but this would be their first for this model. That is why I'm wondering if there are any specs out there. I don't want to send them my radiator to give me a quote if I decide not to pull the trigger. I should also note I don't want a fan that is zip tied. i do want a nice looking solution IF there isn't another option.
Lkunter is offline
post #7 of 17 Old 08-15-2019, 04:59 PM
RedRiverT
Not if his switch doesn't work.
RedRiverT is offline
post #8 of 17 Old 08-15-2019, 05:01 PM
RedRiverT
Do a search on here. There are tons of threads about the 5.9 fan & radiator, and aftermarket upgrades. Search box is at the top left.
post #9 of 17 Old 08-15-2019, 05:06 PM
kg6mov
Hears the voices
kg6mov's Avatar
What switch are you claiming is part of the clutch fan system?
The clutch fans pull more CFM than the efans in most situations.
kg6mov is offline
post #10 of 17 Old 08-16-2019, 09:01 AM Thread Starter
Lkunter
1981 CJ7
There aren't any switches as it is a clutch fan. Also I may be wrong but I thought the electric fan on high speed pulled more if you are just crawling as the RPMs are low. But to your point going down the highway with my heat high and with a clutch fan that is why I am leaning towards a new radiator.
Lkunter is offline
post #11 of 17 Old 08-16-2019, 11:53 AM
Benthal8
Benthal8's Avatar
Yeah, my bad, I think I may have confused the issue because I thought OP meant you were wanting to replace “radiator and switch” lol.
Multitasking = not good!
Benthal8 is offline
post #12 of 17 Old 08-16-2019, 07:26 PM
kg6mov
Hears the voices
kg6mov's Avatar
Correct, if the RPM's are low, like idling, but the temps are hot then an efan can pull more CFM than the clutch fan. The PCM will actually increase the idle RPM (well, a niner might not, but a 5.2 will) if the temp rises to spin the clutch fan faster and get air through the radiator.
Should be plenty of air moving through the radiator at highway, more than either fan will pull. If you're overheating there then you at least have problems other than the fan. It's entirely possible the clutch on the fan is bad as well.
Niner efan is somewhere around 6k CFM on high.
kg6mov is offline
post #13 of 17 Old 08-17-2019, 05:52 AM
V8GCZJ
Is your fan clutch working correctly? If not it won't engage the fan when temps go up. When you first start the vehicle rev the motor up to 2K+ rpm and see if you hear a "roar" from the fan. If so it's working.
V8GCZJ is offline
post #14 of 17 Old 08-17-2019, 10:07 AM
RedRiverT
The one the posters above you were saying could be his problem, after he said he had a clutch fan in place of the e-fan. It was a joke.
post #15 of 17 Old Today, 02:28 PM Thread Starter
Lkunter
1981 CJ7
What temps are the other ZJs with a 5.9 running at (city and highway)? I know my clutch fan is working.
Lkunter is offline
