question about sound from 242 tfc - JeepForum.com
 2Likes
  • 1 Post By PolkaPower
  • 1 Post By kg6mov
post #1 of 10 Old 10-21-2021, 01:40 PM Thread Starter
IdCrisis
IdCrisis's Avatar
Hi i changed my 249 transfercase in my gc zj about 7 weeks ago, drove it for 7ish weeks on 4wd part time cuz my driveschaft was in the shop to be cut ( tock 7 weeks its crazy) anyway after putting in the driveshaft and driving the car in 2wd i get a new wierd transmission whining noice from the transfercase area. this sound dissapear if i put it in 4wd full time. the sound comes over 30 km/h and is constant maby abit louder with higher speeds. what can this be and should i be worried. the tranfercase age and mileage i dont know picked it up from the scrapyard from another zj witch had this swapped in from a 249.
i will this weekend change the oil in the case again because last owner ran gear oil and not aft+4. am i gonna have to do a full rebuild of the transfercase or is this sound normal for the 242 in 2wd?
IdCrisis is offline
post #2 of 10 Old 10-21-2021, 02:28 PM
Timo_90xj
Timo_90xj's Avatar
Whining is most likely a bearing issue. 242 should be next to silent in 2wd, and not much more in 4wd.
***Under construction***
Timo_90xj is offline
post #3 of 10 Old 10-21-2021, 04:33 PM
PolkaPower
PolkaPower's Avatar
Any oil works fine as long as it's thin enough. There's nothing internal that requires atf.
Sent from my iPhone using Tapatalk
PolkaPower is offline
post #4 of 10 Old 10-21-2021, 06:21 PM Thread Starter
IdCrisis
IdCrisis's Avatar
so ill have to take the case down and rebuild it.. or can i still drive with bad bearings until next spring when i get a job after school?
hopefully the thing dont just blow up on me XD, do u need any special tools to rebuild it? can u do it with it still in the car or do u need to have it out? i guess ill have to get a full kit for it.
awell hopefully it lasts about 5 more month without making any dmg to the case cuz i dont have the 2-300 usd to buy the rebuild.
IdCrisis is offline
post #5 of 10 Old 10-21-2021, 06:29 PM Thread Starter
IdCrisis
IdCrisis's Avatar
question when i rebuild the transfercase is this kit ok to buy https://www.ebay.com/itm/191344004948 ??
or where should i get one, i see that rock auto has a kit (but out of stock now )
but is it ok to buy rebuildkits of ebay or should u go to trusted sellers? and if so witch ones do u recomend?
IdCrisis is offline
post #6 of 10 Old 10-21-2021, 06:49 PM
GOLDWING
GOLDWING's Avatar
I can buy one with 127,000 miles for $95 with a 90 day warranty. Why rebuild one when you have to spend more on the parts than buying one?
"The Dude Abides"
"Your axles are going to turn into spaghetti noodles."
Polka Power 1/3/2021
GOLDWING is offline
post #7 of 10 Old 10-21-2021, 07:09 PM
PolkaPower
PolkaPower's Avatar
I don't think he in the US.
post #8 of 10 Old 10-21-2021, 09:32 PM Thread Starter
IdCrisis
IdCrisis's Avatar
XD as polcapower mentioned im not in us, im in sweden eu so not that many jeeps here and the few ones that are here are going up in price, and a 242 from the scrapyard will cost you here about 250-500 usd i paid 1850 sek =215 usd for mine ( after i ordered it 4 more guys tried to get it )
so if i whanna keep it running i have to buy parts and fix it. but i hope i can drive it the short drives i only do about 10 km to and from train every day. awell the tfc will have wait till may when i start working.
IdCrisis is offline
post #9 of 10 Old 10-21-2021, 11:19 PM
PolkaPower
PolkaPower's Avatar
Well we can't tell you how long the bearing will last but I'm going to guess the less it's driven the longer until failure
IdCrisis likes this.
post #10 of 10 Old 10-22-2021, 09:25 AM
kg6mov
Hears the voices
kg6mov's Avatar
I’ve had good luck with the eBay rebuild kits. The bearings and seals are really pretty standard so the kits are just putting all the things you need in a box. The good ones will be the same or better bearings than you’d get from a normal parts house.
Timo_90xj likes this.
kg6mov is offline
