Question about how to reset PCM - JeepForum.com
post #1 of 14 Old 01-14-2010, 02:44 PM Thread Starter
stratons_yj
I read these directions:
Info from a JEEP Technician -
This very simple procedure will Erase the “Adaptive Memory” stored inside the PCM and allow a new “Adaptive Memory” to be developed.
After performing this procedure the PCM will re-learn and store into Adaptive Memory your engines performance characteristics.
Please perform these steps exactly as they are written, in the order they are written. This will cause the adaptive memory in the PCM to be erased and cause the PCM to go into Fast Learn Mode adaptive mode.
Disconnect the POSITIVE battery Terminal and touch it to ground ( not the battery negative terminal ) for 30 seconds. The engine block or the A/C compressor pump will work as a ground. (This is to discharge the PCM capacitors, which maintain the Adaptive Memory.
Reconnect the Battery Cable
Turn Ignition Switch to the “On” position but DO NOT start the engine
Turn Headlight “On”
Turn Headlights “Off”
Turn Ignition Key “Off”
The PCM Adaptive memory has now been flashed, or erased from the PCM.
When you start the engine it will be running off a set of pre-programmed tables that come with the PCM from the factory.
When you get the engine up to operating temperature the PCM will start to collect data for the “Adaptive Memory”.
The PCM will collect data for Adaptive Memory for the first 50 Warm-up Cycles.
BUT....my battery cable's only moves like 2 inches...so I cant reach it to anything.
Can I somehow hook 1 jumper cable end to it and then the other end to the block or something?
stratons_yj is offline
post #2 of 14 Old 01-14-2010, 03:37 PM
Double E
Double E's Avatar
Yes, you can use a jumper to ground the positive cable.
What's the percieved purpose for doing the reset?
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 14 Old 01-14-2010, 04:04 PM Thread Starter
stratons_yj
I'm glad you asked...
On my way home last night I got the P0700 code so I hoping by some miracle chance it will go off and stay off.
post #4 of 14 Old 01-14-2010, 04:08 PM Thread Starter
stratons_yj
Good thing you replied.
Out of all the P0700 related threads, you are the one who sounds like you know what you are talking about
post #5 of 14 Old 01-14-2010, 06:34 PM Thread Starter
stratons_yj
Update:
Tried to reset it 3 times but it didnt go off...
So I just decided to take it out for a drive...and nothing abnormal, no hard shifts, no sluggish shifts, no clunking, no random shifts, and no limp mode.
Counted every gear and overdrive.
I'm definately stumped now...I might have it scanned tomorrow morning.
post #6 of 14 Old 01-14-2010, 08:11 PM
baxy
I reset adapts with the scanner it is ment to be done after either major component replacement or after a tune up
baxy is offline
post #7 of 14 Old 01-15-2010, 07:10 AM
emcneil
Resetting PCM
This worked for me.
Disconnect battery negative cable for 30 minutes.
Turn key to "ON" for 30 seconds.
Turn key OFF.
Reconnect battery cable.
Ed
'98 5.9 Limited - Stone White
NP 242, K&N FIPK, SCT Tune, Kolak exhaust, 3" lift,
255 70 16 Toyo O.C. AT, JKS Track Bars
emcneil is offline
post #8 of 14 Old 01-15-2010, 07:31 AM
baxy
on a chrysler with a JTEC PCM you run the risk or bricking the PCM when you reconnect the battery with the key on so be careful and follow the steps carefully
baxy is offline
post #9 of 14 Old 01-15-2010, 07:53 AM
HighLonesome
HighLonesome's Avatar
I never heard the term bricking, but very good call man.
HighLonesome is offline
post #10 of 14 Old 10-30-2016, 12:40 PM
pacubel
I know this is an old thread but I have a question, if I disconnect the skim and then reset the Pcm, the Pcm will not recognize the skim? My question is in order to disable the skim since I have programmed the key two times and it failed, I'm kind of desperate and had no money for a new Pcm or a new skim and keys
You need a little Guatemala
pacubel is offline
post #11 of 14 Old 10-30-2016, 12:44 PM
Timo_90xj
Timo_90xj's Avatar
ZJs don't have SKIM keys. They have the immobilizer disabling signal built into the key fob.
WJs ('99-'04) Grand Cherokees were the first to receive the SKIM, along with XJs and TJs at the same time.
***Under construction***
Timo_90xj is offline
post #12 of 14 Old 10-30-2016, 04:11 PM
Uniblurb
Uniblurb's Avatar
^ yep, exactly.
I looked at your intro post pacubel and with a 03 WJ you'll have better luck asking questions in the below WJ forum. Good luck.
https://www.jeepforum.com/forum/f310/
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is offline
post #13 of 14 Old 02-04-2017, 07:51 AM
jeff04357
Will this method reset the vin# and mileage also? I want to replace the ECM without having the dealership reprogramming costs.
jeff04357 is offline
post #14 of 14 Old 02-04-2017, 12:37 PM
Timo_90xj
Timo_90xj's Avatar
It will only erase the adaptive memory, nothing more than that.
You need a DRB3 scan tool (or compatible) to do wonders within the PCM.
possible to reset the TCM on a WJ? mailforjon ZJ Grand Cherokee Forum 1 10-09-2008 04:48 PM
How to reset the ECU????? sethfosho ZJ Grand Cherokee Forum 3 01-17-2008 01:35 PM
IAC reset help Yardman Harry ZJ Grand Cherokee Forum 3 09-30-2007 05:29 PM
Question on Malfunction Light/OBD-II reset. KrisR ZJ Grand Cherokee Forum 3 11-22-2005 02:07 PM
How to reset ECU mdevinc ZJ Grand Cherokee Forum 8 06-06-2005 06:59 PM
