Purchasing a 98 5.9 - JeepForum.com
 1Likes
post #1 of 19 Old 02-04-2017, 11:36 AM Thread Starter
Sandy97ZJ
Purchasing a 98 5.9
Getting back into the ZJ game.
Purchasing a BoB 5.9 that has been in my buddy's shop for a while. Everything works, for the most part. Recently had $600 put into it fixing it up. Had trouble passing smog due to a small vacuum leak that was causing a random misfire on cyl #1, setting off the CEL. Now it's passed smog. Has had a decent amount of work, front axle rebuilt. Doesn't look like it's been offroaded much. Has 160k miles but still runs really strong.
I'm paying $2k for it, owner is taking the rims and tires (Which I didn't really want). Plan on putting a 4" lift on it with 33x10.5 K02s.
Decent price, you think? It's a CA vehicle so no rust.
Sandy97ZJ is offline
post #2 of 19 Old 02-04-2017, 12:15 PM
StPaul59
2k for a 5.9 with no rust sounds like a good gamble.
Sandy97ZJ likes this.
StPaul59 is offline
post #3 of 19 Old 02-04-2017, 12:22 PM
Timo_90xj
Timo_90xj's Avatar
Sounds good to me.
Have you checked the tranny fluid, and does the transmission shift fine? Make sure to test the tranny from 0-60mph @ WOT. Even though 5.9s have the 46RE, they don't have an aux. fluid cooler - they can and will cook the tranny fluid fairly easily on warm/ hot climate. Misadjusted bands, or worn clutch packs will most likely cause tranny to slip in 1-2 gear change under hard throttle.
***Under construction***
Timo_90xj is offline
post #4 of 19 Old 02-04-2017, 12:35 PM Thread Starter
Sandy97ZJ
Originally Posted by Timo_90xj View Post
Sounds good to me.
Yes took it for a couple of laps. It pulls hard and shifts fine. I will be adding a cooler for sure, however. Especially since I'm moving to NorCal. Current location doesn't tend to get that hot.
First order of business it to drain all fluids and replace.
My mechanic has also driven it a fair amount diagnosing the smog issue. no problems. Suspension is worn and funky but I'm replacing it anyway...
post #5 of 19 Old 02-04-2017, 12:58 PM
Timo_90xj
Timo_90xj's Avatar
I live in Finland, and the tranny would warm up to and over 250F in summer stop-and-go traffic with only about 65-70F outside temp. Even worse if it happened to be hotter, or when wheeling.
Before I installed the aux. cooler, I had the tranny hit ~260F when wheeling in deep snow in winter... that was pretty much WOT action all day, but anyways.. it was in below-freezing temps. With the aux. cooler, I've never seen it exceed 185F.
Damn sure you will be installing an auxiliary tranny cooler!
post #6 of 19 Old 02-04-2017, 01:11 PM Thread Starter
Sandy97ZJ
Yep I put coolers on all of my vehicles now
post #7 of 19 Old 02-04-2017, 01:22 PM
ZJay1998
Both of my ZJ's had coolers not sure if they were installed before or after. I would pay for one that much. I spent 2K on my first ZJ it had 220K miles no front driveshaft needed new transfer case. No heat A/C needed to be recharged and needed new tires right away.
My second one I paid $1300 for it had 205K miles 4" lift with Bilstien Shocks New headers and exhaust heat and ac worked. After market stereo and kicker audio all the way around along with 2 12" subs. The second one I bought was the better deal for sure.
ZJay1998 is online now
post #8 of 19 Old 02-05-2017, 09:44 AM
Eugnton
Eugnton's Avatar
Do y'all have a recommendation on the tranny cooler? Brand or style? My fluids look good, nice and purple, but I now have concerns after reading this thread.
Red 1996 XJ, SE, 4.0, AX-15, 160,000: Rusty's 3" and 31's. This is XJ number 3 for me!
Eugnton is offline
post #9 of 19 Old 02-05-2017, 12:43 PM
Timo_90xj
Timo_90xj's Avatar
You have a '97, not a '98. '98 is the only model year when ZJs were not equipped with an aux. tranny cooler.
post #10 of 19 Old 02-05-2017, 01:49 PM
StPaul59
I put a cooler on mine at 152k and it shifted fine then. 4 years later all is well. Even found a chunk of snap ring in the pan, still shifts great. Wife overheated the motor till the bottom hose blew off, still runs great
StPaul59 is offline
post #11 of 19 Old 02-05-2017, 02:25 PM
Ace14
I thought all 5.9s had the tranny cooler built into the radiator? I am doing a new rad soon and opting for a separate trans cooler.....
2003 Inca Gold Rubicon-Metal Cloak Armor, Currie Suspension, 35s.
1998 5.9 ZJ -DD/ work in progress
Ace14 is offline
post #12 of 19 Old 02-05-2017, 02:52 PM
Timo_90xj
Timo_90xj's Avatar
All '98s lack the external cooler like I wrote - they only have the radiator loop.
All '93-'97s have the radiator cooler loop + aux. cooler.
Some sources say the '98 ZJs got a slightly better cooling loop in the radiators which is why Jeep dropped the external aux. cooler. In reality, the raditor loop is not effective enough even in cooler climates, let alone in warm/ hot climate. If you own a 1998, an aux. cooler should be included in the tranny cooling circuit.
post #13 of 19 Old 02-05-2017, 02:56 PM
Ace14
Got ya. Are there any write ups or anything showing what fittings and stuff are needed to do to a 5.9?
Ace14 is offline
post #14 of 19 Old 02-06-2017, 08:47 AM Thread Starter
Sandy97ZJ
I haven't taken formal ownership of the vehicle yet so I can't help you out yet... I'll send you some pictures when I do, but I imagine the process is identical to when I did my 97 4.0
Thank you to everyone else for responding to this thread.
post #15 of 19 Old 02-06-2017, 09:07 AM
StPaul59
Ive heard the fittings are different between the 98 and 97s.
StPaul59 is offline
