Power steering toasted? - JeepForum.com
post #1 of 7 Old 03-09-2010, 07:17 AM Thread Starter
noeffort
02 has 59k. I'm doing some maintenance and checked the PS fluid, it has a burnt smell. Steers ok, think I should just flush the fluid and see how she goes?
noeffort is offline
post #2 of 7 Old 03-09-2010, 07:52 AM
bigbill888
definitely yes
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #3 of 7 Old 03-09-2010, 07:56 AM
reckr34
2016 JK Wrangler
make sure you don't use mopar atf+4 or else might make noise
reckr34 is offline
post #4 of 7 Old 03-09-2010, 08:23 AM Thread Starter
noeffort
Originally Posted by reckr34 View Post
make sure you use mopar atf+4 or else might make noise
no atf+4....
Mopar®P/N 04883077 Hydraulic fluid / Power steering fluid (MS5931)
MS5931 IS THE ONLY FLUID THAT CAN BE USED FOR THE POWER STEERING SYSTEM. NO EXCEPTIONS!
Important note:
The factory fill power steering fluid for all 1999-2004 Grand Cherokees is a unique fluid, MS5931. ATF+4 (MS9602) should not be mixed or used as a “topping off” fluid on the Grand Cherokee WJ. All WJ models should be serviced using ONLY the special MS5931 fluid. ATF+4 is NOT an approved Power Steering Fluid and should never be used under any circumstances. Note that all fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
noeffort is offline
post #5 of 7 Old 12-27-2010, 07:31 PM
autoposer
Accidently used off the shelf Power Steering fluid in my 99 Grand Cherokee 4.7L V8. Container says its OK for use with GM and Chrysler vehicles. Didn't do a 100% flush so its mixed with the old stuff. After a few hundred miles I noticed the pump is starting to make some noise. I assume its because I didn't specifically use MS5931 from Mopar. My question is, did I permanently damage the pump? If not, will it eventually damage the pump?
autoposer is offline
post #6 of 7 Old 12-27-2010, 08:21 PM
tcar
NO... Do NOT use ATF in a mopar PS pump. Ever.
Use Chrysler PS fluid or generic that meets Mopar standards.
One of the problems w/ the internet... unless the poster removes that post, it will be there for a long time... someone will read it and think it's OK to use ATF.
tcar is offline
post #7 of 7 Old 12-28-2010, 08:08 AM
reckr34
2016 JK Wrangler
sorry guys I haven't been on in a while and when you leave out one word it changes everything
DO NOT USE ATF+4 IN WJ's IT WILL NOT WORK
SORRY MY MISTAKE
reckr34 is offline
Replaced power steering box. Now steering power comes and goes. bjl95mustang ZJ Grand Cherokee Forum 2 01-02-2010 07:41 PM
Toasted engine on ZJ, any idea what I could get for it? jnocerin ZJ Grand Cherokee Forum 10 12-12-2009 08:57 PM
toasted the engine in my 4.7L kreep ZJ Grand Cherokee Forum 6 11-15-2009 06:56 PM
questions about 4 low and a toasted 249 ShantasticZJ ZJ Grand Cherokee Forum 3 08-25-2009 11:07 PM
VC toasted in 249 arveetek ZJ Grand Cherokee Forum 12 04-17-2008 12:43 PM
