Power steering sometimes heavy at low speed - JeepForum.com
post #1 of 8 Old 07-01-2014, 02:23 AM Thread Starter
AVR2
The steering's usually fine, but occasionally at very low speeds, such as parking maneuvers, it'll get very heavy. Is this likely to be the pump or the steering box?
AVR2 is offline
post #2 of 8 Old 07-01-2014, 02:50 AM
kg6mov
Hears the voices
kg6mov's Avatar
Little bit of both, try doing a flush of the box but it may need rebuilding.
kg6mov is offline
post #3 of 8 Old 07-01-2014, 01:11 PM
Sandy97ZJ
In my past experience it's been the pump. Does it get worse in hot weather?
Sandy97ZJ is offline
post #4 of 8 Old 07-02-2014, 12:38 AM Thread Starter
AVR2
Not really. It's an intermittent thing, it just happens sometimes during low-speed maneuvers.
AVR2 is offline
post #5 of 8 Old 07-02-2014, 02:50 AM
Uniblurb
Uniblurb's Avatar
Sorry to ask but, belt tight/not worn with no-slipping even if it's not making noise and full tire pressure? I'm sure you probably checked and if all is good a PS system change of new fluid may help. You could have something in there restricting the flow control valve.
And speaking of the flow control valve on my 96 4.0 the power steering turns harder than the previous pump which leaked. Have a feeling the flow control valve may not be the same on the rebuilt pump and some say you should change over your current flow control valve over to the rebuilt pump. Or if nothing else count the notches on the high pressure fitting/flow control valve outside nut and they should be the same on a rebuilt pump to have the same amount of pressure.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #6 of 8 Old 07-02-2014, 04:18 AM Thread Starter
AVR2
What are the recommendations for pump replacements? Will a reputable reman be OK? The Mopar ones are just too expensive.
AVR2 is offline
post #7 of 8 Old 07-02-2014, 12:20 PM
Sandy97ZJ
Got mine from NAPA 3 years ago. The added pressure blew out the seals in my gear box within a couple weeks, so I got a new gear box, too.
Ran into PS issues last summer in Texas heat, above 115, similar to yours... felt like I had no PS when turning slowly. Since being back out in CA (9 months now) I haven't had the issue.
YMMV
post #8 of 8 Old 07-02-2014, 12:22 PM
Sandy97ZJ
Oh, make sure you get the right year, and make sure it comes with a new reservoir. (different years come with different reservoirs, and may not fit due to differences in intake manifold)
