Post lift DW question - JeepForum.com
 1Likes
post #1 of 23 Old 05-21-2019, 08:35 AM Thread Starter
Mr. Puddles
My brother and I installed the IRO 3.5 inch foundation lift with new rear springs. We also replaced both front lower control arms as the bushings were falling apart. Got it aligned and over 40 it still has dw. I'm looking for some input on tackling this.
Alignment info
Camber -1.0/-1.1
Caster 6.8/6.3 - Alignment tech said his is the best he could do
Toe .15/.15
Cross camber .2
Cross caster .5
Total SAI 1.6
Last month we installed the Crown HD tie rod assembly. I am planning on replacing ball joints this weekend but I'm not sure if I need to cash out on adjustable control arms and/or a drop pitman arm.
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #2 of 23 Old 05-21-2019, 08:48 AM
HighLonesome
HighLonesome's Avatar
You're going to need adjustable trackbars F/R at least. What size tires?
HighLonesome is online now
post #3 of 23 Old 05-21-2019, 08:56 AM Thread Starter
Mr. Puddles
Originally Posted by highlonesome View Post
you're going to need adjustable trackbars f/r at least. What size tires?
225/75/15.
post #4 of 23 Old 05-21-2019, 09:12 AM
kg6mov
Hears the voices
kg6mov's Avatar
Those alignment numbers look pretty good overall. My biggest issue with the foundation series lift is the lack of front track bar, I would definitely get a double shear bar in there.
You don’t want to start moving the mounts points (drop pitman) unless you know why you’re doing it. The relationship between the track bar and the drag link is the most important part of the bumpsteer/dw equation most of the time. If you were to move the mount for one, you want to move the mount for the other.
kg6mov is online now
post #5 of 23 Old 05-21-2019, 09:49 AM Thread Starter
Mr. Puddles
Ya I wanted to get the Benchmark kit but I HAD to get something to replace worn/failed components and that was all I could afford at the time.
As far as the alignment numbers go I know the caster split is going the wrong way. I also know I have some ball joint play. I don't want to drop the $$ on the LCAs (dropped almost $600 yester day on the first half of my tattoo so I'm a little short on cash) but if that will help resolve the issue Ill do it. As is shes not really road worthy.
post #6 of 23 Old 05-21-2019, 09:59 AM
kg6mov
Hears the voices
kg6mov's Avatar
You’re overall within spec, I don’t see LCA’s improving things since you said you replaced the bushings.
Getting the axle centered with a better track bar would be my first step.
post #7 of 23 Old 05-21-2019, 10:05 AM
HighLonesome
I have a bunch of suspension stuff lying around. Some of it is like new. I'd like to recoup some garage space. PM me if you're interested and I'll see what I got.
post #8 of 23 Old 05-21-2019, 10:58 AM Thread Starter
Mr. Puddles
Ok so do I need the ds front and rear drop bracket or front only?
Last edited by Mr. Puddles; 05-21-2019 at 11:10 AM. Reason: My reading skills suck today
post #9 of 23 Old 05-21-2019, 12:14 PM
Timo_90xj
Timo_90xj's Avatar
Generally drop brackets for just about any suspension/ steering component is a no go.
As far as trackbar goes, NEVER install drop brackets in the rear; in the front some (most) of the double shear brackets drop the trackbar frameside a little, but you gotta be careful to not mess up trackbar and draglink angles. They need to be parallel when observed between their pivoting points.
As kg6mov mentioned, I'd start tracking down your DW issues with a new high quality double shear trackbar + bracket. Front trackbar issues is one of the most common causes for DW, and just about any amount of flex/ play in the trackbar system (brackets, joints, trackbar itself) can and will cause DW.
Have you checked the front axle trackbar bracket mounting hole? It is very common for it to be ovalized, which causes TB play and DW.
***Under construction***
Timo_90xj is offline
post #10 of 23 Old 05-21-2019, 01:31 PM Thread Starter
Mr. Puddles
For the front track bar hole the directions told me to mark and drill a new mount hole which I did. If I do the ds front track bar and bracket wouldn't that mess up the drag link/track bar angles you mentioned? It would seem to me the adjustable track bar would be the better way to go. Unless I'm missing something.
post #11 of 23 Old 05-21-2019, 06:50 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yes, when you lifted the jeep you made the drag link longer (or your steering wheel is off center, doesn't matter), so why the hell would it make sense to move the trackbar mount hole? IRO should bloody know better.
If the track bar and the drag link are parallel and the same length suspension travel won't push the drag link and steering box around.
So yeah, adjustable trackbar is better.
post #12 of 23 Old 05-21-2019, 07:22 PM
GChief
Junior Member
GChief's Avatar
[QUOTE=Have you checked the front axle trackbar bracket mounting hole? It is very common for it to be ovalized, which causes TB play and DW.[/QUOTE]
I told a buddy about this. It was loose and jacked the hole up. He drilled the hole just enough to be round and up sized the bolt to that size with a new bushing. No more DW.
Thanks Rob
GChief is online now
post #13 of 23 Old 06-02-2019, 05:44 PM Thread Starter
Mr. Puddles
Update
Installed the new IRO adjustable Track bar. Got it aligned. Dw still present.
Alignment specs as of today
Camber -1.1/-0.9 (red)
Caster 6.6/6.7 (green)
Toe 0.16/0.15 (green)
Total toe 0.31 (green)
Steer ahead 0.0 (green)
Only thing I can think is its the ball joints causing this.
Sent from my LM-V405 using Tapatalk
post #14 of 23 Old 06-03-2019, 03:50 AM
Zilliver
Can you feel any play in the ball joints, when shaking the wheels?
ī95 Grand Cherokee 5.2
Zilliver is offline
post #15 of 23 Old 06-03-2019, 05:42 AM Thread Starter
Mr. Puddles
Some.
Leaf spring and lift shackle question TheBoogieman XJ Cherokee Technical Forum 9 10-09-2018 10:28 PM
A real "what do i actually need" lift question davikidd ZJ Grand Cherokee Forum 6 10-05-2018 11:05 PM
Replacement shocks for lifted XJ nozzer_tw General Jeep & Off-Road Equipment 2 07-08-2018 04:51 AM
Lift Kit Question jharris1973 Jeep CJ Forum 4 06-04-2018 10:23 AM
Call me stupid, tell me I didn't search the threads-too bad I did. AAl vs RLS HornedFrogHooah XJ Cherokee Technical Forum 23 04-24-2010 12:33 PM
