PCV grommet help - JeepForum.com
post #1 of 15 Old 02-02-2014, 02:34 PM Thread Starter
rhoke
PCV grommet help
Going through some of the idle issue fixes on here. Went to pull the valve out and it crumble and the lower piece of the valve fell into the valve cover. Thank god for baffles. Anyway went to pull the grommet out and it wont budge. Will i need to break that out also. Every other grommet (hundreds) I have replaced were rubber easy in and out. Probably safe to say im in for a trip to O'Reilly for a grommet and valve cover gaskets?
rhoke is offline
post #2 of 15 Old 02-02-2014, 06:02 PM
Oldfrog
2007 WK
Yep. Preferably a fel pro gasket and a dealer supplied grommet.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 15 Old 02-03-2014, 05:01 AM
Kingr98
2016 JK Wrangler
Same thing happened to mine, but I was replacing the PCV and the valve cover gasket anyway. Both the PCV and the grommet had gotten very hard and had to be broken out in pieces.
Kingr98 is offline
post #4 of 15 Old 02-03-2014, 07:54 AM
NYC_ZJ
Jeep for LIFE!!
NYC_ZJ's Avatar
Same thing with my 4.0. I pulled the valve cover and it had a one piece rubber silicon gasket so I was able to clean up the head surface and reuse the old gasket. Over the years and heat, the Pcv rubber Gormet hardens and has to be broken out in order to replace.
1996 ZJ - 4.0 w/ 164,000 miles
3" Rusty's springs, Bilstein 5150's, JKS Quicker Disco's, IRO Adj. Lower Control Arms, Rough Country SS, KOR's adj. TB conv. kit, JKS Rear Track Bar, IRO OTK Steering,
31x10.5x15 Goodyear Dura-trac's on Ultra Rogue Wheels
ZJs Only club member #58
NYC_ZJ is offline
post #5 of 15 Old 02-03-2014, 08:02 AM
PolkaPower
PolkaPower's Avatar
Same here. The rubber gets brittle and hard. It's breaks apart when you try to remove it.
PolkaPower is offline
post #6 of 15 Old 02-03-2014, 11:04 AM
Rikoshay
I ordered a bunch of parts from Rock Auto and they had the PCV elbow and the rubber gasket for about $5.
Rikoshay is offline
post #7 of 15 Old 02-03-2014, 09:23 PM Thread Starter
rhoke
Well. I got it all sorted out without having to pull the valve cover. I tried heat the grommet to see if it helped gettng it out. Haha came out in about a hundred pieces. Now I went with the more expensive BWD PCV valve and its ticking really bad. When you touch the valve itself you can actually feel it. Did I just get a faulty one. Cause I have never had this sound comng from any of the others I have installed
rhoke is offline
post #8 of 15 Old 02-03-2014, 09:27 PM
PolkaPower
PolkaPower's Avatar
It's normal. It will calm down eventually. Its because it's so clean. Clogged PCV's don't make noise.
post #9 of 15 Old 02-03-2014, 11:20 PM Thread Starter
rhoke
Okay thank you.
rhoke is offline
post #10 of 15 Old 02-04-2014, 05:21 AM
jeepjeepster
You have a picture of the rear pcv elbow? Something is missing on mine and idk what it is. The hard plastic line is just stuck back in the elbow but it easily falls out. Think i have the wrong elbow.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #11 of 15 Old 02-06-2014, 04:25 AM Thread Starter
rhoke
Yes- I can take a pic for you later on today and post it. Stay tuned!!
rhoke is offline
post #12 of 15 Old 02-08-2014, 07:55 PM Thread Starter
rhoke
Pic you requested
rhoke is offline
post #13 of 15 Old 02-09-2014, 02:22 PM
jeepjeepster
Appreciate it!
post #14 of 15 Old 04-28-2014, 01:03 PM
wemountainfolk
5.2 Hard PCV Grommet blues
I use a Dremal multi-Max- http://www.dremel.com/en-us/Tools/Pa...spx?catid=2094 To slice the Old and Friggin hard Grommet into quaters. If you are very carefull... You can remove the offending grommet and PCV valve with out dropping crap down into the valve cover. If you do not own one of these things, you have no idea of what your missing! The only thing that I have found more usefull in life, would be wd40!
wemountainfolk is offline
post #15 of 15 Old 04-28-2014, 02:50 PM
AVR2
So much easier on my 93... both CCV elbows use twist-lock fittings, not grommets.
AVR2 is offline
