PCM or Alternator? - JeepForum.com
post #1 of 9 Old 04-23-2017, 09:57 PM Thread Starter
Jeep6488
PCM or Alternator?
I have a 1998 ZJ Grand Cherokee Limited with the 5.9L v8. It started acting like the voltage regulator is out. The voltage hovers around 13 volts but drops when an accessory (say the turn signal or a/c) is turned on and will slowly rise again. I have looked all over the internet and most places say that it is probably the voltage regulator. However, upon further research (and here is where it gets fun), I have learned that the voltage regulator is part of the PCM and is known as an Electronic Voltage Regulator (or EVR/EVR circuit/EVR circuitry). had the Jeep checked an it did come back as the voltage regulator malfunctioning BUT, not a single OBD II trouble code to be spoken of. All this being said, is there a specific trouble code the computer will read if the EVR is bad? and How do I tell if it is the EVR (in the PCM) or if it is just the alternator being the stinker. This whole situation has me very frustrated so any help is greatly appreciated. thanks all.
Jeep6488 is offline
post #2 of 9 Old 04-24-2017, 11:00 AM
kg6mov
Hears the voices
kg6mov's Avatar
With EVR failure we usually see no code, no charge. I would put my money on the alt over the PCM.
Have you cleaned all the grounds?
kg6mov is offline
post #3 of 9 Old 04-24-2017, 02:19 PM
RWC
It's the alternator. Look into the Durango 160 amp alternator upgrade.
RWC is offline
post #4 of 9 Old 04-24-2017, 02:30 PM
wingless
wingless's Avatar
1994 ZJ
Welcome to the forum.
+1 on checking for clean and tight connections. Ensure the battery negative is disconnected prior to working on the wiring.
The alternator is "easy" to test. The small wires on the rear are the field connections. One is at battery voltage. The other is controlled by the PCM, lower voltage = more output.
It is possible to ground the PCM field connection on the alternator to force maximum output, like when doing FSM alternator testing. Grounding that PCM output will create an error code that can be cleared once testing is completed.
This topic shows my alternator testing per the FSM.
The normal 90A or 135A alternators are fine, unless an ear-bleeding stereo amp or other abnormally high current load is part of expected vehicle operation.
wingless is offline
post #5 of 9 Old 04-24-2017, 02:49 PM
hotvak123
2016 MK Compass
Have your battery tested with a load tester if its got caps check the acid level , at the same time use a hydrometer and check the acid specific gravity. clean the post as well, and check grounds frame and engine for corrosion.
you can get a load tester at harbor freight under $20. and hydrometer $2.
or take to auto store they will check it for free.
Alternator only work if the battery is in good shape.
2016 Jeep Compass latitude
2000 Jeep Cherokee with snoway plow
1970 Opel Gt
hotvak123 is offline
post #6 of 9 Old 04-24-2017, 02:59 PM
kg6mov
Hears the voices
kg6mov's Avatar
Don't install a 90A on a 5.9, the draw from the efan is too much. I wouldn't even do a 135A.
kg6mov is offline
post #7 of 9 Old 04-24-2017, 03:28 PM
PolkaPower
PolkaPower's Avatar
Yeah go stock or higher for the 5.9. You can exchange yours for a rebuilt one. I think I paid about 110 for a rebuilt stock 150 with core exchange.
PolkaPower is offline
post #8 of 9 Old 04-24-2017, 04:24 PM
JonS
Originally Posted by hotvak123
Have your battery tested with a load tester if its got caps check the acid level , at the same time use a hydrometer and check the acid specific gravity. clean the post as well, and check grounds frame and engine for corrosion. you can get a load tester at harbor freight under $20. and hydrometer $2. or take to auto store they will check it for free. Alternator only work if the battery is in good shape.
Totally agree!!!
JonS is offline
post #9 of 9 Old 04-25-2017, 12:21 AM
rep-tile
rep-tile's Avatar
OBD I/II won't tell you if the voltage regulator has gone bad, it will only tell you if the charging voltage is too high or too low.
Check your belt tension first to ensure the alternator pulley is properly driven by the belt.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, Jones Exhaust A3518M-5
rep-tile is offline
maintenance , OBD II , repair
