Painting my Grill? - JeepForum.com
post #1 of 30 Old 07-17-2008, 09:20 AM Thread Starter
Jakeb2k4
Painting my Grill?
Hey guys! I want to repaint the black vents on my front grill because they are starting to get a bit faded. My Jeep is silver so i need to mask everything off. What is the best way to clean and prep and whats th e best to use to clean it? Also for my paint choice? i want to keep it black. any suggestions in brands or paint color like satin or gloss? i wast leaning toward rustolium satin black. but i know that krylon has a plastic paint. any tips are appreciated thanks guys
Jakeb2k4 is offline
post #2 of 30 Old 07-17-2008, 09:57 AM
318jeepcherokee
I painted the front of the fins in my grill gold to match the pin stipeing and emblems..it looks real nice, but then a deer hit me and the grill was replaced.. i have yet to re-do them gold, but am planning to.
-1998 grand cherokee 5.9- custom intake, MTX sledge hammer sub with two JBL audio speakers in the rear doors and JVC deck, Westin safari bar with two 6' lights, Yakima load warrior with reverse lights, Hooker aero chamber muffler.
318jeepcherokee is offline
post #3 of 30 Old 07-17-2008, 10:06 AM
IdahoZJGuy
Tape it and use ammonia to clean it real well. Steel wool - fine/med. fine grit will rough it up so the paint sticks. If it's plastic like mine is, use krylon fusion satin black will be good, won't be too shiny, three coats.
IdahoZJGuy is offline
post #4 of 30 Old 07-17-2008, 10:12 AM
Diehard
Diehard's Avatar
What kinda Jeep do you have?
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker.
Diehard is offline
post #5 of 30 Old 07-17-2008, 10:54 AM Thread Starter
Jakeb2k4
did you have any pics of that? sorry about the deer
I have a 1995 Limited
Jakeb2k4 is offline
post #6 of 30 Old 07-17-2008, 10:57 AM
ZJTechie
Depending on your jeep model, it shouldn't be that hard to remove the grill for painting. This would eliminate the need for masking or making potentially painful booboo's on the Jeep. It also allows for you to orient the grill however you want it, thus making the painting process easier and more thorough in the hard spots.
ZJTechie,
My current JEEP score: 205 (see site below)
ZJTechie is offline
post #7 of 30 Old 07-17-2008, 10:59 AM
ajmorell
ajmorell's Avatar
He's talking about just painting the fins in the grille not the actual outer portion of the grille itself.
ajmorell is offline
post #8 of 30 Old 07-17-2008, 11:01 AM
IdahoZJGuy
Yes definately pull it off, when I responded 'Tape it' before I meant tape the areas you don't want to paint. Getting it off the rig is definately idea for doing the job - of course based on the model it can be easy or it can be tough.
post #9 of 30 Old 07-17-2008, 11:32 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Ignore the lights...I got new lights and a header panel to install...
Jeep Sold! 02/2009
Need AMSOIL?
LaCeS OuT is offline
post #10 of 30 Old 07-17-2008, 11:47 AM
318jeepcherokee
sorry no pics.. when i painted the front of the fins i just used a foam brush and just was carefull and brushed it on..no tape , no over spray and it looked good!..P.s Laces out-lovin' the white grill on the white jeep looks great!
post #11 of 30 Old 07-17-2008, 11:49 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
Thanks!
10char
Jeep Sold! 02/2009
Need AMSOIL?
post #12 of 30 Old 07-17-2008, 11:54 AM
LaCeS OuT
LaCeS OuT's Avatar
1994 ZJ
If you want to paint it the same color, go to www.paintscratch.com and order the spray cans to match the color of your jeep.
Jeep Sold! 02/2009
Need AMSOIL?
post #13 of 30 Old 07-17-2008, 12:04 PM Thread Starter
Jakeb2k4
i just want to paint the vents and yes i know how to get the grill of i just want to repaint the darker black vents because they are faded i will remove the grill and mask aoo all my silver paint. should i use that krylon plastics paint? and wash with amonia?
Jakeb2k4 is offline
post #14 of 30 Old 07-17-2008, 01:28 PM
footinmouth47
footinmouth47's Avatar
yep the Krylon is the best to use. just rough up the surface and blow off all the dust wipe it down and paint (you probably dont need amonia but if you want go for it). if you want it more glossy put a gloss clear coat over it.
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline
post #15 of 30 Old 07-17-2008, 01:30 PM
madrabbitt
madrabbitt's Avatar
NO AMMONIA!
it'll damage the plastic.
Honestly, all you really should do is take it off, and clean it well (those steel wool pads with the soap work really well) and then just hit it with krylon fusion in your choice of color.
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
Good Spray Paint For Chrome Grill - Black Grill coryg23 ZJ Grand Cherokee Forum 2 06-18-2009 10:56 PM
Painting factory grill inserts EricF07 WJ Grand Cherokee Forum 12 02-02-2009 09:00 PM
Painting Grill JrMechanic ZJ Grand Cherokee Forum 6 01-05-2009 11:05 AM
Painting a 05 WK front grill? Ryanb08 WK Grand Cherokee & XK Commander Forum 9 07-06-2008 09:45 PM
Painting a 02' Grill, Self or Pro? snow1214 WJ Grand Cherokee Forum 2 01-19-2004 08:29 AM
