p0601 error. Can i fix this myself? - JeepForum.com
post #1 of 15 Old 03-31-2008, 11:41 AM Thread Starter
Guiness92
Hello, I have a problem with my cherokee. I took it to inspection and failed for emmisions. They gave me a code of p0601. I did the onboard diagnostic check and came up with the same code. But that is showing to be an internal pcm error. Is there any way to reset this code without having to go to the dealership with it? The Jeep runs perfectly fine and I really see no reason why the check engine light would be on at all.
Any help would be appreciated.
Thanks, Ron
Guiness92 is offline
post #2 of 15 Old 03-31-2008, 12:21 PM
MuddyLuxury
MuddyLuxury's Avatar
we need some info on the jeep, year? engine? model? if its a cherokee you will prolly have more luck over in the XJ forum, but none the less we need this info to help ya out
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #3 of 15 Old 03-31-2008, 12:41 PM Thread Starter
Guiness92
sorry, its an 01 cherokee laredo with the 4.7. It has about 137k miles and runs perfectly.
post #4 of 15 Old 03-31-2008, 12:49 PM
WJChris
WJChris's Avatar
GRAND cherokee, or CHEROKEE?
WJChris is offline
post #5 of 15 Old 03-31-2008, 12:49 PM Thread Starter
Guiness92
grand cherokee
post #6 of 15 Old 03-31-2008, 12:52 PM
MuddyLuxury
you can try un hooking the battery for 15-20 minutes and let the system fully discharge and see if that clears the code, it could be that once the code is gone the light will remain for a certian number of ignition cycles post code correction. if i remember that right the number is 100
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
post #7 of 15 Old 03-31-2008, 12:56 PM Thread Starter
Guiness92
Thanks for the info, Ill try that first and let you know how it worked out.
post #8 of 15 Old 03-31-2008, 03:06 PM Thread Starter
Guiness92
Well, I disconnected the battery for 15 minutes and started it up and the check engine light was off yay. I turned it off and checked for the code. No code!! Great, well I later started the jeep again, and the light was back on. Checked for the code and it was back Should I repeat until its gone again?
post #9 of 15 Old 03-31-2008, 03:10 PM
UUJ1
Guest
Well, advanced auto will scan your codes for you for free. I don't know if the DRB has the capability of clearing codes, but to prevent yourself form going to the dealer, I would at least ask.
UUJ1 is offline
post #10 of 15 Old 03-31-2008, 03:26 PM
WJChris
WJChris's Avatar
you already proved the code will come back.
You are treating the symptom, not the cause.
P0601 (M)
Internal Controller Failure
Internal control module fault condition (check sum) detected.
WJChris is offline
post #11 of 15 Old 03-31-2008, 03:39 PM Thread Starter
Guiness92
ok so what needs to be done to correct the cause of the problem? No idea what the internal controller is.
post #12 of 15 Old 03-31-2008, 03:41 PM
WJChris
WJChris's Avatar
If I can make some time Ill go look at MY FSM and see where that leads.
This is no easy fix, and you may have to spend some coin to get it repaired.
Not all problems are repairable over the internet, sometimes you have to get in there yourself
WJChris is offline
post #13 of 15 Old 03-31-2008, 03:47 PM Thread Starter
Guiness92
ok thanks, I appreciate the help. I thought it was just as easy as clearing the code, but if I have to, Ill take it somewhere to get it fixed lol.
post #14 of 15 Old 04-01-2008, 10:06 PM Thread Starter
Guiness92
autozone came up with the same code, p0601, said he had no idea how to fix it. I asked him if he could clear the code and he said yes he could but he wont. Said since I have a rejected sticker on the windshield, he isnt allowed to clear the code by law
post #15 of 15 Old 04-01-2008, 10:19 PM
MuddyLuxury
sounds like you need a new PCM or a PCM flash
-Jeb
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
Go Doorless!
Things i need..
Error in FAQ? HighLonesome ZJ Grand Cherokee Forum 7 01-29-2010 02:21 PM
Bad MPG or HUD error? BHand89 ZJ Grand Cherokee Forum 8 11-12-2009 03:10 PM
Please Help 352 Error code LightShow_WJ ZJ Grand Cherokee Forum 7 04-30-2008 09:56 PM
03 4.0L TPS error tsconver ZJ Grand Cherokee Forum 0 02-09-2008 01:50 PM
DTE error? vtbert3 WK Grand Cherokee & XK Commander Forum 6 05-20-2007 07:45 PM
