Opinion on steering replacement. - JeepForum.com
 3Likes
  • 1 Post By CatSplat
  • 1 Post By Noble One
  • 1 Post By jcjunkie
post #1 of 13 Old 01-19-2020, 03:32 PM Thread Starter
jcjunkie
jcjunkie's Avatar
My tie rod ends and drag link ends are worn out. While lubing up all the joints, they have cracked boots seeping grease..
So obviously two ends are fixed.
I think that's ridiculous so you have to buy a whole rod to get an end..
Anyway what's best, but a new drag link and tie rod or upgrade to OTK steering as to have replaceable ends?
98 5.9
jcjunkie is offline
post #2 of 13 Old 01-19-2020, 11:15 PM
Kolak
Vendor
Kolak's Avatar
Is your Jeep lifted or stock height?
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #3 of 13 Old 01-20-2020, 04:46 AM Thread Starter
jcjunkie
jcjunkie's Avatar
It's has a 6" lift currently.
98 5.9
jcjunkie is offline
post #4 of 13 Old 01-20-2020, 11:35 AM Thread Starter
jcjunkie
jcjunkie's Avatar
After talks with Andy from Ironman 4x4 and research I'm going with all Moog replace ment.
A tech guy from Moog made this. Hope it's helpful to others.
jcjunkie is offline
post #5 of 13 Old 01-20-2020, 11:42 AM
wingless
wingless's Avatar
1994 ZJ
This reply shows the Moog parts I used on my Up Country ZJ.
wingless is offline
post #6 of 13 Old 01-20-2020, 12:58 PM
1996maroonzjf
1996maroonzjf's Avatar
If you going stock style, talk to Kolak about the Crown HD steering upgrade. I’ve been running mine for over 50K miles between 2 ZJs. I’ve also done quite a bit of towing and wheeling in the Rockies and the Crown kit is holding up nicely.
-Tim
(2) '96 4.0s
#1-'10-'18
#2- HP30/Ford 8.8 - 4.56, OME HDs, 5100's, IRO Adj Arms/Track Bars
1996maroonzjf is offline
post #7 of 13 Old 01-20-2020, 01:09 PM Thread Starter
jcjunkie
jcjunkie's Avatar
Ok thanks man.
Is crown comparable to Moog quality.
98 5.9
jcjunkie is offline
post #8 of 13 Old 01-20-2020, 01:29 PM
CatSplat
CatSplat's Avatar
1994 ZJ
The Crown HD setup is good, I ran it until I upgraded to WJ parts. My only complaint was that the Crown TRE boots were pretty crap, I replaced them with Energy ones after they split.
1996maroonzjf likes this.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
post #9 of 13 Old 01-20-2020, 03:07 PM
1996maroonzjf
I’m also running energy suspension dust boots, but Kolak claims crown has upgraded their boots after he raised the issue with them.
-Tim
(2) '96 4.0s
#1-'10-'18
post #10 of 13 Old 01-20-2020, 04:26 PM
Noble One
Noble One's Avatar
Ok, I know I am very new to all this, but......
Isn't there a significant issue with him using stock moog set-up on a 6 inch lift? Steering geometry is going to be way off.
Kolak likes this.
Noble One is offline
post #11 of 13 Old 01-20-2020, 06:09 PM Thread Starter
jcjunkie
jcjunkie's Avatar
I have a few thread with various issues I've tried to get some input..
But I am going to purchase 4.5 coils from kolak, so I'll be at 4.5.
Kolak likes this.
98 5.9
jcjunkie is offline
post #12 of 13 Old 01-21-2020, 05:34 AM
Timo_90xj
Timo_90xj's Avatar
Stock steering setup at 4.5" lift isn't ideal either, at 6" it simply sucks. IMHO about 3" is the limit for properly functional steering- and trackbar geometry without going OTK - and even at that height OTK makes a difference.
OTK at 3" lift height will give you stock geometry, OTK @ 6" of lift will be the same as stock steering at three inches of lift. You do need to raise the axle bracket up when going OTK, so it requires welding.
You can run stock- style under-the-knuckle steering at lift heights above 3"-4", but do not expect the steering geometry to be good.
***Under construction***
Timo_90xj is offline
post #13 of 13 Old 01-21-2020, 07:23 AM Thread Starter
jcjunkie
jcjunkie's Avatar
That's a very thought out answer and I appreciate it very much very good explanation. What would be your recommendations on a steering upgrade for a four and a half inch lift.
I don't know how wranglers get away with that all I see are lifted wranglers everywhere and they are pretty high and it looks like stock steering?
98 5.9
jcjunkie is offline
