OK to Remove Driveshafts? - JeepForum.com
 1Likes
  • 1 Post By kg6mov
post #1 of 10 Old 07-09-2019, 07:33 AM Thread Starter
CatAndTie
'96 Grand Cherokee Limited, Quadra-trac (full time 4wd), 202,100 mi, 5.2l
1. As the title says, I want to double check to make sure I can safely drive without the front or rear drive shaft (obviously one at a time and not for an extended time).
I have some vibration and noise that I want to start narrowing in on. I suspect something with my driveshafts. From browsing through the forums I think I can drive without the shafts with my model Jeep but want to confirm.
2. As a follow up, are there any good writeups, videos to recommend to measure driveshaft angles? I've never measured the angles since I've had the Jeep so I have no idea what I'm even looking for or doing. I found a few generic videos of other cars and I'm assuming it will be the same process, but wanted to check with you guys.
I'm going to get a gauge soon to rule that out. My Jeep is loud and it's getting annoying!
CatAndTie is offline
post #2 of 10 Old 07-09-2019, 09:10 AM
PolkaPower
PolkaPower's Avatar
96-98 is safe to remove the front shaft.
Sent from my BND-L24 using Tapatalk
PolkaPower is online now
post #3 of 10 Old 07-09-2019, 09:19 AM Thread Starter
CatAndTie
OK, that's what I thought.
Can it be driven with just the front driveshaft and the rear driveshaft removed?
post #4 of 10 Old 07-09-2019, 09:48 AM
Timo_90xj
Timo_90xj's Avatar
4lo only. If you're in AWD, removing rear shaft will cause huge strain on the VC, so you would fry it really quicly.
***Under construction***
Timo_90xj is offline
post #5 of 10 Old 07-09-2019, 09:50 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yup, in 4lo you can pull the rear shaft, but it would be the equivalent of pulling the front on a first gen case if you tried it in AWD.
When you have it in 4lo and FWD you are legally required to post a video of the front wheel burn out you do.
Benthal8 likes this.
kg6mov is offline
post #6 of 10 Old 07-09-2019, 10:53 AM Thread Starter
CatAndTie
LOL, I will keep that in mind then!
So pulling the front (only driving with the rear) I can keep it in 4W All Time, and when I pull the rear driveshaft (only driving with front) it needs to be in 4lo and I will need to post a video of a burnout?
post #7 of 10 Old 07-09-2019, 11:12 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yup, youíve got it.
Donít run for too long with the rear shaft removed on an internal slip yoke case, some of the fluid will leak out the back.
kg6mov is offline
post #8 of 10 Old 07-09-2019, 11:36 AM
Timo_90xj
Timo_90xj's Avatar
It's also worth mentioning that it is not a good idea to apply wide open throttle with the rear DS removed unless you are planning on replacing the R&P.
post #9 of 10 Old 07-09-2019, 11:38 AM
Timo_90xj
Timo_90xj's Avatar
Plastic soda bottle cut open, duct taped to rear output housing.
post #10 of 10 Old 07-09-2019, 03:13 PM
CatSplat
CatSplat's Avatar
1994 ZJ
True that. I ran on the front shaft for a couple of weeks while I was driveshaft shopping post-SYE and man did I ever baby that thing. No way that axle was designed to run as the primary mover.
1994 5.9L ZJ | IRO 5.5" CPLA | NP242 | 33" Cooper Discoverer STT Pro
The Jeep of Theseus
CatSplat is offline
