OBD codes - JeepForum.com
 1Likes
  • 1 Post By jtec
post #1 of 6 Old 01-27-2020, 05:10 PM Thread Starter
Wolfeman1992
Wolfeman1992's Avatar
1994 ZJ
OBD codes
Alright one of you walking encyclopedias pulled my ZJs codes and I keep finding different answers on what they mean 12 13 22 55
94 ZJ 4.0 4.5" on 31s
Wolfeman1992 is offline
post #2 of 6 Old 01-27-2020, 05:22 PM
jtec
jtec's Avatar
2014 JK Wrangler
12* . . . . . . . . . . Battery Disconnect
13** . . . . . . . . . . No Change in MAP From Start to Run
22** . . . . . . . . . . ECT Sensor Voltage Too High
55* . . . . . . . . . . Completion of diagnostic trouble code display
* mil off
** mil on
jtec is offline
post #3 of 6 Old 01-27-2020, 05:26 PM Thread Starter
Wolfeman1992
1994 ZJ
Ok so 13 is troubling 22 make sense since the connector is broken, thank you
post #4 of 6 Old 01-27-2020, 05:56 PM
jtec
jtec's Avatar
2014 JK Wrangler
13 should be easy- check for vacuum to map, check elec connector.
small rubber vac seal at TB.
jtec is offline
post #5 of 6 Old 01-27-2020, 06:01 PM Thread Starter
Wolfeman1992
1994 ZJ
I say troubling because I replaced the MAP sensor already
post #6 of 6 Old 01-28-2020, 01:12 AM
jtec
jtec's Avatar
2014 JK Wrangler
Map sensor 3 wires.
#3 violet with white - is 5v referance
#2 red with white center of connector is signal
#1 black with lt blue is ground
with KOEO - leave connected - what is voltage
#3 wire ? should be @5v
#2 wire? should be @ 4 to 4.5
#1 confirm a good ground.
Start engine #2 should change and go lower - opening throttle it should move YES or NO?
have fun
Wolfeman1992 likes this.
jtec is offline
