NP249J Viscous Coupler & Alignment - JeepForum.com
post #1 of 6 Old 12-13-2017, 05:02 PM Thread Starter
Sandy97ZJ
Could really bad camber and toe cause the viscous coupler to bind up?
Sandy97ZJ is offline
post #2 of 6 Old 12-13-2017, 05:50 PM
wingless
wingless's Avatar
1994 ZJ
The common causes for NP249 viscous coupler failure are: long service mileage; excessively high ambient temperature; excessive viscous coupler heat caused by low transfer case fluid level and excessive viscous coupler heat caused by non identical tire outside circumference.
wingless is offline
post #3 of 6 Old 12-13-2017, 11:45 PM
nicyousuckk
I'm going to go with no, but those alignment issues can cause similar symptoms to those commonly associated with a failing VC.
nicyousuckk is offline
post #4 of 6 Old 12-14-2017, 08:44 AM Thread Starter
Sandy97ZJ
Thanks!
post #5 of 6 Old 12-14-2017, 08:48 AM
jeepjeepster
I'm curious, how does long service mileage hurt the VC? Assuming the TC isn't ran low on fluid.
1994 ZJ-I6 w/270,000 mi
1998 ZJ 5.9 w/66,000 mi Slate Black
2004 KJ w/108,000 mi
jeepjeepster is offline
post #6 of 6 Old 12-14-2017, 08:57 AM
wingless
wingless's Avatar
1994 ZJ
The long service mileage failure means that a properly-maintained part (w/ correct transfer case fluid level and w/ identical circumference tires) will eventually wear out and fail.
wingless is offline
