Non Lifted 95 XJ Axle not centered - JeepForum.com
 1Likes
  • 1 Post By kg6mov
post #1 of 10 Old 07-26-2017, 01:15 PM Thread Starter
djplatinum50
Non Lifted 95 ZJ Axle not centered
Hey guys Im Tom. Just picked up a new to me 95 4.0!!! Excited to build it out. Currently working on the normal stuff.... tie rods, brakes, cosmetics. One thing I'm stumped on is why my front axle is off center. There is no lift on it so it's not that. She rides good, no wobble or anything. Any ideas, I tried searching but it's only about once the truck is lifted mines is stock. I know i can get an adjustable track bar but I will want to drill down what could cause it to be off.
Thanks,
Guys
djplatinum50 is offline
post #2 of 10 Old 07-26-2017, 01:23 PM
jm8881
This will probably get moved very soon since this is the ZJ section but I would check your control arms and mounts on the frame and axle for anything bent. Good luck with the "new" jeep!
jm8881 is offline
post #3 of 10 Old 07-26-2017, 01:27 PM Thread Starter
djplatinum50
Sorry thats a typo its a ZJ
post #4 of 10 Old 07-26-2017, 01:49 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Off centered....side to side or front, center, rear of well?
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 10 Old 07-26-2017, 02:04 PM
clrkent67
Double check for any possible prior collision damage that wasn't fixed properly. It may require a little time on aframe rack. It doesn't mean it's junk. It just may have been something that was overlooked and easily fixed buy a professional shop.
Sent from my SM-G930P using Tapatalk
clrkent67 is offline
post #6 of 10 Old 07-26-2017, 02:25 PM Thread Starter
djplatinum50
Thanks guys and its off centered side to side so the drivers side wheel is further out the fender than the passenger side. (just as if it was lifted)
I was hoping it wasnt a frame issue.
post #7 of 10 Old 07-26-2017, 02:29 PM
kg6mov
Hears the voices
kg6mov's Avatar
Take pics of the front end. It could be a bent track bar, or the PO may have had a lift on there and halfassed removing it.
clrkent67 likes this.
kg6mov is online now
post #8 of 10 Old 07-27-2017, 08:54 AM
LordHobbit
LordHobbit's Avatar
One wheel spacer and one not?
93 red ZJ 199k 4.0. Spent more money than I should have ...
LordHobbit is offline
post #9 of 10 Old 07-27-2017, 03:14 PM
ljc1968
Hi, I have similar problems, 98 ZJ, after fitting new lower control arms, identical size, axle had moved back and had to ratchet strap it forward to get bolts in, now axle forward over an inch and prop now too short
ljc1968 is offline
post #10 of 10 Old 07-27-2017, 03:37 PM
kg6mov
Hears the voices
kg6mov's Avatar
You have completely different problems, please start your own thread.
