No start no run - JeepForum.com
post #1 of 39 Old 08-13-2019, 05:35 AM Thread Starter
travispierce504
travispierce504's Avatar
No start no run
I just got this 96 Laredo v8 4x4 it ran wen my bos an i parked it now just cranks an cranks dont know what to do help plz
travispierce504 is offline
post #2 of 39 Old 08-13-2019, 08:37 AM
jtec
jtec's Avatar
2014 JK Wrangler
maybe look to see -
spark at several cylinders.
fuel pressure*
check for any codes.
* try spraying some carb cleaner into TB as someone tries to start jeep - did it hit/fire and try to start on the spray?
jtec is offline
post #3 of 39 Old 08-13-2019, 12:00 PM
igorhandsome
igorhandsome's Avatar
Do you hear the fuel pump run when you turn the key on?
igorhandsome is offline
post #4 of 39 Old 08-13-2019, 01:29 PM Thread Starter
travispierce504
Sprayed it changed out distributor cap roter coil started for 5 seconds then died out back to no fire to coil
post #5 of 39 Old 08-13-2019, 01:47 PM
jtec
jtec's Avatar
2014 JK Wrangler
With key moved to run or start is there 12 v at coil and injectors?
The dark green over orange wire should get 12v from asd relay.
jtec is offline
post #6 of 39 Old 08-14-2019, 09:51 AM Thread Starter
travispierce504
I check at the throtle poposition sencer i was getting between 4.7 an 5.0 om a multi meter
post #7 of 39 Old 08-14-2019, 11:28 AM
jtec
jtec's Avatar
2014 JK Wrangler
why are you checking TPS ?
Did you retrieve codes maybe ?
jtec is offline
post #8 of 39 Old 08-15-2019, 11:45 AM Thread Starter
travispierce504
No coads just no run no start
post #9 of 39 Old 08-18-2019, 11:24 AM Thread Starter
travispierce504
Checked at the relay like you said it has 12 there. About to check the injectors. I also unplugged the pcm it loocked fine no carosan pretty much bran new loocking desides dust on out side where do i check next
post #10 of 39 Old 08-19-2019, 11:13 AM Thread Starter
travispierce504
There isnt 12 to the coil like 4 or 5
post #11 of 39 Old 09-14-2019, 02:20 AM Thread Starter
travispierce504
I just got finished replacing the crankshaft position sencer no fire still any suggestions after that
post #12 of 39 Old 09-14-2019, 07:56 AM
V8GCZJ
Do this!!! You need to see if you have power at the coil(+ positive on the coil). Keep in mind that the asd relay will shut off(with the key in on position) after a few seconds.
Even if there are no codes you should get a "55" witch means end of codes using the key dance. Are you seeing this? If not there may be an issue with the pcm.
https://www.quadratec.com/jeep_knowl...article-24.htm
V8GCZJ is offline
post #13 of 39 Old 09-14-2019, 01:12 PM Thread Starter
travispierce504
I have no reading of power at connector for coil at ASD I have 13 or 12.57 will try the key thing in a little while
post #14 of 39 Old 09-14-2019, 01:22 PM
Some_Anchovies
Some_Anchovies's Avatar
How long was it parked for?
95' ZJ 4.0L, 5-Speed Swap, NP231, 275k
Ex-Master Mechanic-turned-Software Developer
Some_Anchovies is offline
post #15 of 39 Old 09-15-2019, 01:37 PM Thread Starter
travispierce504
About a year an a half to a year to almoast 2 years
