No start issue - JeepForum.com
 4Likes
  • 1 Post By kg6mov
  • 2 Post By yjsaabman
  • 1 Post By HighLonesome
post #1 of 10 Old 07-14-2021, 11:32 AM Thread Starter
das13
1994 ZJ
No start issue
Hello and thank you to all the amazing members here. I have used this site for the last 7+ years to keep my baby running. Unfortunately, she is not currently running. I'll list what I have done and am willing to take any and all suggestions. Thanks in advance.
1994 Grand Cherokee Laredo
5.2 engine
272k miles
The issue started with a stumble/hesitation off idle. When stopped at a light the engine would idle fine but upon initial throttle application would stumble a bit. After 1-2 seconds rpm's would increase and throttle response felt fine. No loss of power or stumble after the initial throttle tip in. This happened about 5-6 times in one trip, it hadn't happened before. I shut it off and restarted it about an hour later with the same issue. I was at the bottom of a large hill and hit the throttle to accelerate up the hill and the engine stopped. I coasted to a stop and could not restart the Jeep. It would crank but not catch.
I suspected the fuel pump was bad and replaced it. That resulted in no change, still cranks and will not start. When I turn the key to the on position I can hear the fuel pump powering on.
I attempted to pull codes with the key on-off-on-off-on and retrieved no flashing lights.
The check engine light stays on for about 3 seconds when I turn the key to on and then goes out.
I cleaned the battery terminals
I cleaned the ground located below the alternator on the passenger side of the block.
I removed the wire connector from the PCM and cleaned it. I wiggled the PCM.
I checked and cleaned all relays in the PDC and cleaned the positive wire attachment point
I have 11.5+ volts with the key on according to the dash. It drops below that when I attempt to start it but still cranks.
I have a half tank of known good gas.
I have replaced the fuel pump with a new Delphi unit
I was unable to test the coil but see no scoring or other indication of damage.
I am unable to access the distributor cap due to location. (If I need to be tougher or more monkey like, let me know).
I looked at the O2 sensor wiring as much as I could which isn't much and didn't see any issues.
Any suggestions would be greatly appreciated, thank you again and have a good one.
Jon
das13 is offline
post #2 of 10 Old 07-14-2021, 12:27 PM
kg6mov
Hears the voices
kg6mov's Avatar
Yes, climb on into the engine bay and think thin thoughts then have after the cap and rotor. Go around the intake not over it.
I also don't see plugs on your list.
I'd basically throw an old school ignition tune up at it as a baseline.
3hounds likes this.
kg6mov is offline
post #3 of 10 Old 07-14-2021, 01:26 PM Thread Starter
das13
1994 ZJ
As I was sitting here I thought the same thing. Time to stop being a sissy. Thank you. I'll update after it is done.
das13 is offline
post #4 of 10 Old 07-15-2021, 04:16 AM
yjsaabman
1930 CJ2
Diagnose, don't throw parts at it. Air, fuel, and spark are what the engine needs to run. You know you have fuel pumping, but is it getting to the rails? Do you have spark? Do you have injector pulse? When you pull the spark plugs pay close attention to the condition, are they fuel soaked?
No flash codes at all is odd, as it should at least give you the end code, even if there aren't any others.
Sent from my SM-G970U using Tapatalk
jtec and 3hounds like this.
yjsaabman is offline
post #5 of 10 Old 07-15-2021, 04:35 AM
jtec
jtec's Avatar
2014 JK Wrangler
spark check is there spark at several plugs. And as mentioned READ them.
Fuel pressure PSI- yes I see new pump but new ≠ good.
jtec is offline
post #6 of 10 Old 07-15-2021, 04:56 AM
V8GCZJ
You may be doing it to slow or fast. Keep trying it you should get a 55 code meaning end of codes even if there are no codes set.
V8GCZJ is offline
post #7 of 10 Old 07-15-2021, 10:10 PM Thread Starter
das13
1994 ZJ
Hello All and thanks for the responses so far. I didn't get a chance to do anything on the Jeep today. Tomorrow I'll try to retrieve codes again and pull the distributor cap to see if there are any issues there. I'll also see if I can get spark. Thanks again.
das13 is offline
post #8 of 10 Old 07-16-2021, 01:31 PM
HighLonesome
HighLonesome's Avatar
You changed the fuel filter along with the pump I assume. There is a fuel regulator at the rail which can fail. I sort of recall it is vacuum driven, so give that a check. A pressure check at the rail will cover all that.
Sure diagnosis is best, but just replace the coil. They are cheap, and if it doesn't help, throw it under the rear seat as a spare. You may not 'see' anything wrong with a coil. What happens over time is the insulation on the internal wiring breaks down, and they short out. Or they become intermittent dependent on heat.
3hounds likes this.
HighLonesome is offline
post #9 of 10 Old 07-19-2021, 10:43 AM Thread Starter
das13
1994 ZJ
Hello, I did replace the filter at the same time as the pump. I wasn't able to do anything on the Jeep this weekend. I'll update when something changes. Thanks again.
das13 is offline
post #10 of 10 Old 08-02-2021, 03:22 PM Thread Starter
das13
1994 ZJ
Hello and thanks again for the help. Life got in the way and I wasn't able to do anything to the Jeep until this morning. I pulled a plug and had my wife crank the Jeep. Spark was weak and erratic. I replaced the coil and she started right up. 272k miles and the boy and I got ice cream. Life is good again in my Jeep. Thanks to everyone.
das13 is offline
