No Heat!!!! - JeepForum.com
post #1 of 9 Old 12-16-2009, 04:22 PM Thread Starter
divewall14
2003 WJ
No Heat!!!!
Hi, I have a 03 grand cherokee limited with the dual climate control but the drivers side heat will not work. the passengers side blows hot but the drivers side blows cold. i was told that this is a problem with the ducts but is there an easy way to fix this?
divewall14 is offline
post #2 of 9 Old 12-16-2009, 04:24 PM
Morgen251
Morgen251's Avatar
2010 JK Wrangler
Shoot the ducks. Then make a phone out of them. Call for help.
2010 JK Wrangler. Born to me on 12/28/09 when El Jeepo (TJ) decided 160K was enough, and threw a rod through a cylinder.
BUILD:
Rubi Rocker Guards; 32" Mastercraft MTs; Teraflex 2.5" Coil Spring Lift; JKS Quick Discos; JKS Front & Rear Adj Trackbars; JKS Ex Rear Swaybar links; Zone Nitro Shocks; 1.5" Rough Country Wheel Spacers; Poison Spyder Evap Skid; Cobra 75WXST; 3' Firestick quick disco; Rugged Ridge XHD Fr Bumper; Tuffy Underseat Drawer; 6" KC Long Range Hilites; Superchips Flashpaq, Crown Extended brake lines
WISH LIST: Front LCAs, Winch, 6" KC Driving Lights, Deep Cycle Battery
Morgen251 is offline
post #3 of 9 Old 12-16-2009, 04:50 PM
straty1987
go to the AZC self-diagnostic mode and see what code you get then can see if you need a blend door fix or a new motor
Jeep Grand Cherokee WK - Climate controls
here is my write up that lets you keep the dual control
https://www.jeepforum.com/forum/f13/d...p-pics-884932/
straty1987 is offline
post #4 of 9 Old 12-16-2009, 05:07 PM
cmonson
blend doors
search heater treater
cmonson is offline
post #5 of 9 Old 12-16-2009, 08:53 PM
Double E
Double E's Avatar
Giggle Giggle....Laredo for the win!!!!
Do the recommended search given above or be ready to part with about $1k.
"We have it totally under control. Itís one person coming in from China. We have it under control. Itís going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
post #6 of 9 Old 12-17-2009, 06:31 AM
cmonson
don't let this guy scare you. The heater treater is a permenant fix to the issue. Cost is just over $100 and takes 45 mins to fix. Personally I WAY rather have a limited.
cmonson is offline
post #7 of 9 Old 12-17-2009, 04:02 PM
straty1987
X2
but look into getting the dual control fix if you want to keep that and is not allot more for the kit
post #8 of 9 Old 12-17-2009, 07:58 PM
USA_PRIDE
1979 CJ7
heres an free method you can try and will only take about 1/2 hour. remove the glove box, or drop it own out of the way. you will see the actuator towards the left side of the glove box area. unplug he actuator and remove the two phillips screws the hold the actuator to the ac/heater box. now you should beable to turn the blend door manually. with the car running and up to temp. turn the blend door back and forth and see if you can get any temp. differences. this worked on my '99 wj. of course you wont beable to adjust the temp on the driver side. if this doesnt work for you then replacing the blend doors is your next option. good luck!
2011 Wrangler Unlimited Rubicon- Flame Red
1999 Grand Cherokee Limited
God Bless All The Men And Women Who Served And/Or Is Serving This Great Country!
Proud To Be A FF/EMT/Police/Military Club Member #3
USA_PRIDE is offline
post #9 of 9 Old 12-18-2009, 01:00 AM
myjeeplovesmud
myjeeplovesmud's Avatar
i fail to see how laredo's ever win, after owning a few, i'm cozy in my limited. and best part, i don't have to push it up hills, and i'm able to pass people when the urge comes. don't give me the line about them having the 4.7 optional, it's H.O or nothing
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
November 2010 GCOTM
myjeeplovesmud is offline
99 WJ with manual ac/heat controls blows heat then turns cold GA350 ZJ Grand Cherokee Forum 10 01-04-2009 10:59 PM
I need more heat jeepin4evr ZJ Grand Cherokee Forum 4 10-08-2008 04:12 PM
No Heat!! justjeepin ZJ Grand Cherokee Forum 3 10-06-2008 05:58 AM
Manual Heat Only (No Auto Heat) FFuries ZJ Grand Cherokee Forum 0 09-27-2008 06:25 PM
Blend Door Woes! No Heat! No Heat What so ever 3 ERROR CODES! Polaris Junkie ZJ Grand Cherokee Forum 4 09-20-2006 11:05 AM
