No dashlights or tail lights - JeepForum.com
 2Likes
  • 1 Post By Boojo35
  • 1 Post By Boojo35
post #1 of 6 Old 10-15-2021, 09:07 PM Thread Starter
4xphate
4xphate's Avatar
1994 ZJ
My blinker lights work on dash and bright light. No tail lights but brake lights work. Just happened this morning, any ideas? My electrical knowledge sucks.
1994 grand cherokee
4xphate is offline
post #2 of 6 Old 10-15-2021, 10:10 PM
Boojo35
1987 YJ Wrangler
Check your fuses first. That will lead you down the first path. Dash and tail are a shared fuse in most vehicles.
4xphate likes this.
If you cannot fix it with a hammer then it has to be an electrical problem.
Boojo35 is offline
post #3 of 6 Old 10-15-2021, 10:25 PM
tvengineer
Could be the ignition switch. I had a similar problem with my 93 GC and turned out to be contacts in the ignition key switch.
tvengineer is offline
post #4 of 6 Old 10-15-2021, 10:57 PM
Boojo35
1987 YJ Wrangler
Please tap out right now. Dash and tail lights are powered by B+ which means hot at all times. It has nothing to do with the ignition switch.
4xphate likes this.
Boojo35 is offline
post #5 of 6 Old 10-16-2021, 09:09 AM Thread Starter
4xphate
4xphate's Avatar
1994 ZJ
Is there another fuse box other than under hood and under glovebox? All those look good, it wouldnt be a relay would it? Found it, was #12. Thanks man.
4xphate is offline
post #6 of 6 Old 10-18-2021, 04:59 PM Thread Starter
4xphate
4xphate's Avatar
1994 ZJ
Yeah, I made it less than 1/4 mile before blew again. I believe its my headlight switch for anyone searching this subject. It will be in tomorrow, if I dont update that was it.
4xphate is offline
