Newb question..wiring to battery - JeepForum.com
post #1 of 10 Old 01-07-2015, 05:19 PM Thread Starter
justfishin20
So Im wiring a radio to my battery...do I just loop the exposed end of the power wire to the positive battery post, and then connect the ground to a bolt on the chassis? or do I need a special connector to the battery?
justfishin20 is offline
post #2 of 10 Old 01-07-2015, 05:24 PM
kg6mov
Hears the voices
kg6mov's Avatar
Radio radio or stereo radio?
In both cases I would suggest against going directly to the battery. If you're trying to wire in a CB the cigarette lighter circuit has more than enough oompf. You can also use an add a fuse to tap off another circuit inside the jeep.
kg6mov is offline
post #3 of 10 Old 01-07-2015, 06:01 PM Thread Starter
justfishin20
its a radio scanner for police frequencies, it suggests going straight to battery
post #4 of 10 Old 01-07-2015, 06:16 PM
kg6mov
Hears the voices
kg6mov's Avatar
A scanner draws mouse nuts for current. Cigarette lighter circuit or add a fuse definitely. You can tack on to the back of the lighter socket pretty easily.
This was the power line to my transmitter in the niner.
kg6mov is offline
post #5 of 10 Old 01-07-2015, 10:29 PM
1998_ZJltd
Yea ... but you know what your doing .....
OP should step away from the battery for a minute and rethink if he should be doing any electrical additions to the ZJ ...
I know we all learn at sometime but ....
1998_ZJltd is offline
post #6 of 10 Old 01-08-2015, 12:34 AM
siguy
i run an additional distribution block from battery to run all my after-market accessory's
siguy is offline
post #7 of 10 Old 01-08-2015, 12:01 PM
kg6mov
Hears the voices
kg6mov's Avatar
This. For the power hungry stuff like my 100W transmitter or lights I run a set of relays on their own circuits. I trigger the relays off the cigarette plug so it all comes on with ignition but I also have override switches so I can leave the radios on while the engine is off.
None of that is warranted for a scanner though. That thing probably draws less power than my GPS.
kg6mov is offline
post #8 of 10 Old 01-08-2015, 02:15 PM
Roadtripguy
I use these for auxiliary power needs in my truck. They are fast, and "plug and play." I keep a few extras in my wiring box.
http://www.ebay.com/itm/ADD-A-CIRCUI...item4ae2f8795a
Roadtripguy is offline
post #9 of 10 Old 01-09-2015, 06:41 AM Thread Starter
justfishin20
ive never had a problem with the add a fuses, ive added plenty of things...I ended up going to an add a fuse for this scanner, thanks guys
post #10 of 10 Old 02-12-2015, 09:00 AM
Thedawgshow
Hmmmm..... I like these. My Uniden set up rom right channel radios will be her today. I might need to order this.
DAWG
My pappy was a pistol, I'm a son of a gun.
Thedawgshow is offline
