New ZJ Battery Cables - JeepForum.com
 6Likes
post #1 of 23 Old 11-17-2013, 05:28 PM Thread Starter
Shanebear
1994 ZJ
After replacing the battery terminal clamps on my '94 ZJ, I've decided I'd like to replace the entire positive and negative cables themselves. Will any generic replacements work? I haven't had much luck finding anything
Shanebear is offline
post #2 of 23 Old 11-17-2013, 05:34 PM
WJ4x4LIFE
If you would like to replace the first part w/disconnects by factory it is a P/N: 56018913 . If you would just like to replace it with generic gauge wire and not running anything special look for 4 gauge red and black, I know O'reilly's sells it by the FOOT.
WJ4x4LIFE is offline
post #3 of 23 Old 11-17-2013, 05:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Make your own. It is so much more satisfying when you do.
Luck Favours The Prepared
Anticanman is offline
post #4 of 23 Old 11-17-2013, 06:39 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Or hit me backchannel?
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 23 Old 11-17-2013, 08:21 PM
blackjack12982
blackjack12982's Avatar
1994 ZJ
Got any examples? I'm in the market...
blackjack12982 is offline
post #6 of 23 Old 11-17-2013, 10:07 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That's the opposite of the back channel.
post #7 of 23 Old 11-17-2013, 11:45 PM
Uniblurb
Uniblurb's Avatar
Hey Anticanman, do you need a ban hammer to go with that ban anvil? LOL, j/k!
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #8 of 23 Old 11-18-2013, 01:07 AM
5-90
5-90's Avatar
1988 XJ Cherokee
PM Sent
5-90 is offline
post #9 of 23 Old 09-02-2019, 10:43 PM
Rigged For Adventure
Defib applied.
I had to cut my battery cables in order to put new battery terminals. One of the positive wires ended up being a hair too short and doesn't properly secure in the new battery terminal, but fits just enough. I'd like to extend that cable if possible. I looked at the cable from under the Jeep, but didn't see any way at first sight. Has any one been able to extend it or did you just end up buying new battery cables?
Rigged For Adventure is offline
post #10 of 23 Old 09-03-2019, 04:52 AM
066
Make sure you're using OFC wire if you build your own. Do not use CCA.
066 is offline
post #11 of 23 Old 09-03-2019, 05:45 AM
vijayasree5
Make it on your own and you feel it quite satisfying.
vijayasree5 is offline
post #12 of 23 Old 09-03-2019, 11:43 AM
I wouldn't even know how to build this. How easy is it to build your own and how easy is it to install new ones?
post #13 of 23 Old 09-03-2019, 12:51 PM
Mr. Puddles
Not a big BJ fan after he needlessly destroyed an Orvis but this isnt a bad video
Follow the build!
2002 Dakota aka Winnie aka Mad Max
1996 Grand Cherokee aka Puddles aka Pikey Life
Originally Posted by kg6mov View Post
The 4.0 is dumb old tractor motor, itís too stupid to know itís supposed to die.
Mr. Puddles is offline
post #14 of 23 Old 09-03-2019, 01:53 PM
jeeepguy
jeeepguy's Avatar
Try these... it's what I used...
Custom Battery Cables
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #15 of 23 Old 09-16-2020, 01:51 AM
I'm finally tackling this project soon. Does anyone have a write up on this? I see the ZJ installation guide on CustomBatteryCables.com, but I'm wondering if anyone has a more detailed write up.
https://www.custombatterycables.com/...-modification/
