New Radiator - Different Transmission Line Connections - JeepForum.com
post #1 of 5 Old 07-19-2015, 09:22 PM Thread Starter
MnM
Hello,
I picked up a new radiator and it came with different fittings.
The radiator has threaded female holes, and my 95 Laredo 4.0 has a threaded male fitting coming off the top and a barbed fitting coming out the bottom
What type of fitting do i need to connect to these?
I figure I can go two routes:
1. find a way to connect that snap ring piece to my current hoses (pictured)
2. find a different piece to screw into the radiator then worry about how to make the connection to the hose
Any help would be greatly appreciated.
Thanks guys!
MnM is offline
post #2 of 5 Old 07-20-2015, 12:18 AM Thread Starter
MnM
I read that: "The trans side fittings are NPT and I'm pretty sure the radiator side are standard inverted flare."
after some research, I think this is the piece I want for the upper line:
Straight, 3/8 Tube Inverted Flare with 5/8-18 Male to -6 AN Male
For the lower line, I think I want a standard inverted flare on the radiator side with a 90 degree bend and a barb fitting
Does this/these sizes sound correct?
MnM is offline
post #3 of 5 Old 07-20-2015, 05:45 AM
PolkaPower
PolkaPower's Avatar
Yes that "sounds" correct. In my experience with the v8 they are all 3/8 flared ends. Standard will not screw in all the way.
PolkaPower is offline
post #4 of 5 Old 07-21-2015, 02:23 PM Thread Starter
MnM
Does anyone know what type of flare the radiator or hose has?
AC (Air Corp Standard) also called Parker Triple Fitting (NOT Triple-Lok)
AN (Air Force - Navy Aeronautical Standard)
AND (Air Force - Navy Aeronautical Design Standard)
AS (Aerospace Standard)
MS (Military Standard)
JIC (Joint Industry Council)
SAE 37° also called Parker Triple-Lok
ISO 8434 (1986), ISO 8434-2 (1996)
SAE 45°
MnM is offline
post #5 of 5 Old 07-21-2015, 02:58 PM
kg6mov
Hears the voices
kg6mov's Avatar
ZJ is JIC 37 which is compatible with AN 37 and I think SAE 37.
kg6mov is offline
connection , connector , fitting , radiator , transmission
