new PCM question - JeepForum.com
post #1 of 14 Old 02-02-2019, 06:55 PM Thread Starter
SWB
new PCM question
I have a 97 ZJ with 187K. 4.0
Got the ZJ running great after following the "12 step program" and was gaining confidence in it again. Then decided to install re-manned PCM I had ordered from Flag1. before finding ground issues.
New (re-man) PCM jeep shut down after 3 seconds, consistently. Key locked and unlocked Driver door and tailgate. No change
Re-install old PCM and no issues. Starts, runs and drives fine.
Is this because the new PCM is not compatible with my security system? (or its current state? I'm not the original owner)
Any suggestions welcomed and thanks in advance
Scott
SWB is offline
post #2 of 14 Old 02-02-2019, 07:03 PM
ZeeJay1997
If the current PCM and security system perform as advertised, it sounds like they sent the wrong PCM.
ZeeJay1997 is offline
post #3 of 14 Old 02-02-2019, 07:23 PM
klaxmaster
klaxmaster's Avatar
Scott
Why get a new PCM? If it IS needed, just go to a junkyard and get one for 50. Chances are its still good and no one had pulled ot from the jeep yet.
Sent from my LM-G710 using Tapatalk
If it ain't broke, fix it with a larger part.
klaxmaster is offline
post #4 of 14 Old 02-03-2019, 03:40 AM
Camaro16
Put the old PCM in, if it wasn't causing you any problems - then return or Ebay the new one - they have sent you the wrong PCM, the new one has security and the old one did not.
Camaro16 is offline
post #5 of 14 Old 02-03-2019, 09:23 AM
jtec
jtec's Avatar
2014 JK Wrangler
felt like changing the PCM
If it ain;t broke don't F with it.
Let us know customer service and any hassles returning the 'bad' PCM... for future referance
jtec is offline
post #6 of 14 Old 02-03-2019, 10:48 AM Thread Starter
SWB
Called Flag1 this AM. Agreed it is a programming issue. Said my jeep didn't have security (I thought it had been disabled or removed) and that the replacement was programmed accordingly but possibly didn't take. Asked if I wanted to try again. Told them yes. 2nd unit is being programmed and sent.
The greater emphasis was placed on the return of the unit with as much info as I could give so they could learn what went wrong. So far very easy to deal with and seemed on top of their game.
As to why I chose to replace it:
If you have ever dealt with a random no warning flame out situation(s) I shouldn't have to explain much here.
These units are prone to failure (proven), At this point of my life $187 is a cheap alternative to being insecure.
Weak grounds (all repaired now) can cause PCM and sensors to fail.
Darn near everything grounds through the PCM.
SWB is offline
post #7 of 14 Old 02-11-2019, 11:33 AM
97grand8165
97grand8165's Avatar
Part of what we have to deal with old jeeps. Mostly computer related .
97grand8165 is offline
post #8 of 14 Old 02-11-2019, 11:43 AM
StPaul59
Always the 4.0 it seems.. Why don't the V8s go bad? Anyone know?
StPaul59 is offline
post #9 of 14 Old 02-11-2019, 05:15 PM
ZeeJay1997
Just an educated guess... the v8 boards were furnished by a different supplier.
post #10 of 14 Old 02-13-2019, 12:13 PM
97grand8165
The trouble is the computer thinking for the human and or motor.
post #11 of 14 Old 02-13-2019, 01:00 PM
Crystina Tutter
does anyone know where i can order a replacement PCM for a 94/95 jeep grand cherokee laredo? i ordered one but it was wrong part and found one on ebay but the wires were cut at the base of the box to short to splice into place. I need one because mine caught fire under the hood and is a chard pile of plastic now. please if anyone as one with the wiring connected or knows where i can order one i would greatly appreciate it thanks
Crystina Tutter is offline
post #12 of 14 Old 02-13-2019, 05:44 PM
RedRiverT
kolakperformance.com probably has them. They guy that runs it posts on here (username "kolak").
Or you can go to a used parts junkyard and maybe find one. A lot of those places check their other locations and will have one removed and sent to them, then you can go pick it up.
You have to get one for the same type of engine, whether it has a factory security system or not, and whether it is originally from California.
RedRiverT is offline
post #13 of 14 Old 02-14-2019, 01:06 AM
Kolak
Vendor
Kolak's Avatar
If you need the connectors and some of the wiring, best to go to a salvage yard. Make sure it's the same model year/engine size as your ZJ.
I can assist with a remanufactured PCM. You can PM me here on the forum or email me at [email protected] and we'll chat.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #14 of 14 Old 02-14-2019, 05:15 PM
jeep210
When I had my random engine stalling issue, my troubleshooting led me to the PCM. I got a reman from AutoZone and it has been running great since the change. I got charged a $10.00 core charge so I kept my old PCM. Figured I can get it repaired and used again if needed.
jeep210 is offline
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 448 05-28-2019 07:14 PM
Overland PCM Question NW Hillbilly WJ Grand Cherokee Forum 1 01-02-2019 05:44 PM
PCM programming question rcroane TJ Wrangler Technical Forum 16 10-02-2018 09:18 AM
2010 5.7L WK PCM swap question Pepe73 WK Grand Cherokee & XK Commander Forum 0 09-19-2018 07:00 PM
2001 GC PCM Question drickman9 WJ Grand Cherokee Forum 15 01-30-2018 07:29 PM
