New to me 94 Laredo - Page 19 - JeepForum.com
 32Likes
post #271 of 279 Old 09-22-2021, 01:46 PM Thread Starter
DirectMatrix
Got everything all buttoned up and topped up. She started after a bit of cranking. Sounds good, but I have a pretty bad fuel leak at the fuel pressure regulator right next to the distributor cap. Not the best place to troubleshoot a fuel leak.
Don't really want to pull the driver's side fuel rail but that's probably what it's going to take to diagnose.
Also, why did it take me so long to buy one of these special coolant funnels!?!?!!!
PXL_20210922_194257395_1632339941004.jpg   PXL_20210922_190609905_1632339977989.jpg
GOLDWING likes this.
92 YJ, Delilah
DirectMatrix is offline
post #272 of 279 Old 09-22-2021, 02:12 PM Thread Starter
DirectMatrix
Seals look ok on the regulator which is where is appears to be coming from. You can see a drip in the corner of the flange when I turned the key to power up the fuel pump and build pressure.
PXL_20210922_201054147_1632341559650.jpg   PXL_20210922_194937705_1632341569493.jpg
92 YJ, Delilah
post #273 of 279 Old 09-22-2021, 02:42 PM Thread Starter
DirectMatrix
Cleaned the mating surfaces and inspected the o-rings. Is there a rebuild kit for this? Nothing wrong with the regulator, just need new o-rings.
I suspect the bracket isn't putting enough pressure on the regulator for a seal. Going to try and make some shims.
92 YJ, Delilah
post #274 of 279 Old 09-22-2021, 03:05 PM Thread Starter
DirectMatrix
Shim didn't work. Used cork gasket material to try and get the hold down bracket to apply more force. No dice. On the hunt for a regulator or an o-ring rebuild kit.
92 YJ, Delilah
post #275 of 279 Old 09-22-2021, 04:53 PM Thread Starter
DirectMatrix
Looks like the 53030001 part number for the pressure regulator is the same as my YJ. Maybe I'll just swap and confirm the issue. But, then again, do I want to open that can of worms on my YJ????
92 YJ, Delilah
post #276 of 279 Old 09-23-2021, 06:40 AM Thread Starter
DirectMatrix
Decided late last night not to mess with the YJ and just ordered a new regulator for the ZJ from Jeff Bezos. Probably should have went Mopar, but I went with Delphi. The Mopar ship date was Oct 1 and I can't wait that long. Need to get this project finished. Only time will tell if a new one fixes the leak and if there's any fuel pressure delivery issues.
If that isn't the issue, then I might have torqued the whole fuel rail assembly and put too much pressure on the fitting below the regulator, but I don't think that's the case. The fuel seems to be coming up from the top side, not migrating from the back. The other fittings seem to be ok.
There are $9-$10 regulators on ebay with free shipping. Thinking about picking one up just for the gaskets. I found a new gasket set on ebay from Crown, and its $21 just for the gaskets.
92 YJ, Delilah
post #277 of 279 Old 09-24-2021, 05:35 AM
HighLonesome
HighLonesome's Avatar
I found these. Still around from back when I had my '94 V8 ZJ. I won't ever need them again. One is a new Standard brand and the other is used Mopar. I recall it being good. IM me if you want them.
HighLonesome is offline
post #278 of 279 Old 09-24-2021, 10:48 AM Thread Starter
DirectMatrix
Generous offer and much appreciated. PM sent
92 YJ, Delilah
post #279 of 279 Old 09-25-2021, 08:04 AM Thread Starter
DirectMatrix
Started and running. No more fuel leaks after the new regulator. I took the gaskets off the Delphi unit and put them on my stock Mopar unit. Sounds like I'll get some freebies from New Mexico soon.
I'm a bit disappointed in the whole situation. The long crank at startup is still present. I thought that would be cured as part of this.
The oil pressure gauge still fluctuates even with the new sending unit.
The exhaust sounds good and no more rattling. The engine overall sounds quieter but I detect the occasional stumble. Nothing is reflected on the scanner as far as rpm drop goes, but I can hear it.
As best as I can tell, there is no more smoke at startup, so that's something.
I guess I just had higher expectations for the amount of components changed.
92 YJ, Delilah
